Just some info if anyone is interested in replacing their worn out front seats on their liberty. I have a 2002 limited and my leather seats were falling apart. Driver's side had torn leather, had to weld the frame in several places where it had cracked and the recline mech broke. So I found a set of very nice, although not the same color, black leather seats from a 2012 liberty for $250! All the info I found, said no way they will fit. Well they do. Mounting points are almost the same. Big difference is the wiring. Also seat belt buckle sensor. Old seats use a hall effect sensor and magnet, while new ones use a simple switch. Found that out after install when my airbag light came on! The new seats are power with heat and memory function. Memory function will not work of course and I did not hook up the heat, even though the old ones have it. Don't need heated seats, the Arizona sun does that already . Here are some pictures. If you need details on what needs to be moded I can try to help out.
