Hi all,
It looks like my sunroof drain on the front passenger side has detached from the grommet.
I can barely see the end of the drain hose and water drains out from it but it doesn't look like it has an elbow at the end of it like I would expect, comparing it to the figure in the part fische. I can't quite reach it with my hands as it's behind the padding behind the dash.
I think I can get to it with some long nose angled pliers which I don't have. I am hoping to not need to remove the dash to get this fixed.
Here's where I need help
1. Can someone please verify for me where the drain hose grommet is located?
2. Is there suppose to be an elbow fitting at the end of the drain hose?
3. where does the water drain out from? the side by the door hinge?
If someone can do me a solid that'll be great. No tools required at all to help me.
Just need to remove the side kick panel(?) right below the glove box, on the right. It just pulls right out.
One you've pulled out the trim, you'll see this.
Right above this white harness protective molding, you'll see an orange cable that connects to the black cable you see in the picture. I think this is the radio antenna cable.
On my jeep, right above this orange cable, I see another grommet.
Is this the grommet that the drain hose needs to connect to?
Thank you in advance for any assistance you can provide!
