My 2.5" done.
Celticlady
Progressive Ranco spring rear.
2927 rock father front springs
with OME struts front
Aftermarket extended upper control arm front.
Stock control arm rear. If moog decides not to replace it under their lifetime warrantee I will go off road. They have replaced it twice.
See my other post on replacing drivers seat with after market Cordeau. I am still happy with it.
mercdudecbr600
That's a real clean front steel bumper + winch... custom? Also, how's the lift holding up against the winch?
Celticlady
I built the bumper. I looked and looked. Could not find any that worked for me. They either required major frame modifications, removal of the washer bottle. Or were skimpy. All were $2-3000.
Took about 2 months. Bolt on using the saddle forward bolts as the anchors. Its modual. So I don't have to drop the whole thing to do maintenance. I can have either side off in about 10 min. The center would require the winch removal.
I can get to everything in the front without pulling that.
1/8 (10 gauge) weighs 55 lbs. plus the winch weight. I have OME struts and springs that are sized for the bumper
mercdudecbr600
Having installed a detours winch bracket and accompanying warn winch on my KJ, I'm impressed.
