Muffler choice
mindbomb
California
Need to replace my banged up rusted OE muffler + its rubbing on the rear driveshaft U-joint badly when right rear wheel stuffs.
I mainly look for:
  1. solve rubbing problem - need to be narrower than OE muffler body by at least 1-2 inches
  2. any minor increase in low rpm torque would be nice
  3. durability for off roading
  4. deep sound but not too loud
  5. reasonable price / availability
Was thinking Thrush welded:
Thrush® Welded Muffler - Center / Offset - Thrush® Exhaust P/N: 17650 - Thrush® Exhaust, Making Hot Rods Hotter Since 1966™
Good choice?
Any other recommendations?
P.S.
I need center inlet, offset outlet, 2.5" dia pipes?
Magnaflo does great, nit loud but nice tone.
Have them mount it so front is where stock was or a bit forward , most are shorter so that will take care of the rubbing
mindbomb
California
Any specific model of Magnaflo?
Other suggestions? thought 80% of the peeps here changed their stock muffler...
My 03 is still running stock
Ran Magnaflow on the 04 after getting rid of the awful FlowMaster
Magnaflow was a shorter than stock one I picked up at the parts store
Elliott
Florida
I went with Gibson when I needed to replace mine. Looks good and sounds pretty close to stock.
kejobe
NE Ohio
Mine has a Thrush turbo (#17717). Was on it when I bought it. Doesn't drone or anything inside. In fact I didn't even know it was aftermarket till I looked under. Can't hear it when driving but does have a bit of a rumble outside.
Here's a quick vid I took today. Was recorded with an iphone 6, so...not the best but gives an idea.
https://www.youtube.com/watch?v=vtOI6S3MHNo
mindbomb
California
Hey thanks for taking the time to record that.
Sounds very quiet, pretty stock-ish.
I was thinking about the welded model, I believe it gives a bit more low rumble. Donno about more power at low rpms, if this myth even exists...
Wondering if this is the correct model (Thrush 17650) for the KJ:
http://www.thrushexhaust.com/mufflers/thrush-welded-muffler/thrush-welded-muffler-center-offset-17650.html
dude1116
Pompton Plains, NJ
I have a magnaflow. The model # escapes me, though. It was a fairly short bodied, center/offset model (same setup as our Jeeps).
Myke
USA
Did you really post a URL as text and color it blue? :signs75:
