M10x1.5 rivet nut extra available
M10x1.5 bolt and rivet nut extra available
I have extras if anyone need them.
Updated info:
M10 × 1.5—Head: Wd. 15 mm, Ht. 10.4 mm
Product Detail
Class 10.9 Steel Flange Head Cap Screw, M10 Thread, 1.5mm Pitch, 35mm Long, Fully Threaded
McMaster-Carr
Product Detail
Zinc-Plated Steel Heavy-Duty Rivet Nut, Open End, M10x1.50 Interior Thread, .7-3.8mm Material Thickness
McMaster-Carr
yup.
that's what's on the part fiche and I also measured it.
The transfer case bolts are 35mm compared to 30mm with the engine skid.
I am looking to purchase the 35mm
Jo6pak
Left coast of WI
Sorry for the late reply.
I'd be interested in a few if you have extras. I'll need them if I ever track down a front skid plate for cheap.
yup. I do realize that.
I will be ordering a half hex replacement from avondalewholesaleparts.com, however, I need to drill two holes in the cross member and half hex wont work with that.
Jo6pak
Left coast of WI
Thanks for the heads-up Leeann. I would need the hex style....but jeez, I don't need 100 of them:shrug:
Leeann
Maryland
Yeah, no one does. I bought mine at my local Jeep dealer.
Do you need any non hex style rivet nuts? I'm adding a ****** skid plate so I need to add some rivet nuts to my cross member.
The MOPAR part number is 6505294AA for their rivet nuts.
bump.
I'm planning to order a minimum pack of 10 rivet nuts that will work with M10x1.5 bolts from mcmaster-carr.
It has knurls around it to resist spin. These are round ones, not the hex rivet nuts.
I'll also be ordering the 10.9 grade m10x1.5 bolts with 35mm length.
I just need to use 2 of each item.
Let me know!
Updated info:
Product Detail
McMaster-Carr
Product Detail
McMaster-Carr
