Lugs
I replaced mine with Mopars a year ago, but I expect they will deteriorate the same as the originals, the more my tires are rotated. If I were to replace them again, I’d look for some that are solid metal instead of chrome plated. The chrome caps come off and the interior nut is an odd size.
TimberWolf
Las Vegas
I replaced mine with an all steel set from Autozone, not too costly if i remember right, even came with a 5th lug for each wheel so they couldn't be taken off without the special lug adapter. I was totally fed of with my torque wrench spinning the caps off. I've been satisfied with them since putting on.
Yes many things were designed quite well on the Jeep!
Unfortunately this is not one of them...;)
Mike Phelps
Thank you
And here I am with all stock lug nuts in great shape on all 3 of mine
That is what happens when you use air powered tools on them
Absolutely true.
I have lifetime free tire rotations at the shop where I bought my tires, so my lug nuts are going to see impacts.
Mike Phelps
Mine all turn, they’re just rusty at all the seams. Steel wool can only do so much
Just hangin' out.
A bit late to the game, but I just replaced mine with the Dormans. They are solid, but use a larger socket size on your tire iron and torque wrench. None of that open end stuff with a stamped cap that always fails and let’s the weather into your threads.
When I mount my steel wheels, I got black chrome solids to go with the black wheels and black center caps.
