Lower control arm replacement
randymorris
Phoenix, Arizona
I’m replacing rear upper and lower control arms, and on the passenger side, my muffler is blocking me from removing the body side bolt of the lower control arm. Any suggestions on how to get it out without removing the muffler?
Royy
Western CO
Just undo the two bolts on the flange directly in front of the muffler. The muffler will then just be hanging from the two exhaust hangers, and you can push it to the side far enough to get plenty of space to remove the bolt.
randymorris
Phoenix, Arizona
That worked. Thank you sir!
randymorris
Phoenix, Arizona
So now I have a different issue. The bolt on the passenger side upper arm just spins part way out. Is there a way to get to the other side without cutting carpet?
Royy
Western CO
Try just pulling the bolt downwards, while rocking the control arm back and forth. If the sleeve in the bushing is not perfectly aligned with the holes in the bracket, it puts enough pressure on the bolt to make it very hard to get it out. If I remember correctly there's only an inch or so of threading in the nutserts that the bolt threads into.
randymorris
Phoenix, Arizona
So I got the bolt out. The sleeve in the bushing was my problem after all, which is much better than what I thought was happening. The sleeve damaged the threads on the bolt, which is why it got stuck and was just spinning. Now to get new bolts so I can get the new control arm in.
