Loose gas cap
bluetick
New England
The check engine light went on in my Liberty. Naturally I immediately checked the gas cap and it was loose. But even after three clicks it was still loose. So I bought a new gas cap. Same problem; three clicks and it's still loose. I'm stumped.
You went to a Jeep dealer and got a MOPAR OEM gas cap????
teeje
Toledo
Sounds like you might have an evap leak somewhere. Get it smoke tested
2002 Jeep Liberty 3.7L with brand new engine ;)
bluetick
New England
But why would the cap remain loose even after tightening it three clicks?
Loose in what manner? Does it wobble side to side?
Check the rubber sealing washer to be present and not compressed.
It should look like this...
55482[/ATTACH]"]
If you are not sure return it and try another one...
colorado76
Rocky Mountain High
If the cap was not the fix. Then start with the purge solenoid. But when I had this issue. It was the EVAP leak detection pump. Hope that this information helps you out.:happy160:
bluetick
New England
Ok, I started it up today and no check engine light. By the way, when I said it was loose, I mean turning it three clicks didn't tighten it. Not side to side, but circularly.
Counting My Blessings
You can crank that think forever, if you want to, at least I can on my 2007.
I had the same thing happen a couple months ago, except in my case it actually said "loose gas cap" on the dash. It took me a couple times of removing/replacing it but it finally went out and stayed out. I blame the Kardashians. :mexsmoke:
My stock gas cap also doesn't like to stay tight, its caused a check engine light before. If you tighten it, then try to loosen it, its as if it was never tight at all. Just comes right back off.
If I put some weight into it when tightening it, it seems to stay tight.
