Looking for a little insight
Discussion in 'KJ General Discussion' started by LibbyLover, Feb 23, 2020.
  1. LibbyLover
    LibbyLover New Member
    Feb 23, 2020
    A couple months back I bought 2003 Jeep Liberty Sport 4x4, 3.7L engine, automatic transmission, and only 104,000 miles for dirt cheap! The owner swore up and down that it had a bad head gasket and that was all that was wrong. I did test drive it and figure out really quick that it was a broken valve cover gasket, not the head. Had that confirmed by 3 separate mechanics, fixed it myself, along with spark plugs, oil change, and 2 vacuum hoses he "fixed" with tape. Since then, I've discovered a few more of his "fixes" on things I'm planning on doing anyways, first one being replacing the upper and lower radiator hoses because I found the lower hose wrapped with tape under the clamp, thermostat, water pump with a new belt and a coolant flush, and the other fix is partially my fault, I read the oil cap, not the book. I discovered the oil cap had been replaced with one that says 5W-20, not 5W-30 like the owner's book and parts stores recommend. I plan to use 5W-30 full synthetic, but do I have anything to worry about from using the wrong oil? Is there anything else I should check and/or replace? I'm eventually going to replace all the exterior lights and back door and glass because previous owner used the spare tire as a stopper and the door is dented, and the glass is only holding on to a third of the latch. Thanks a bunch!
  2. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    6,769
    265
    Welcome. As far as the oil goes 5W-30 is the correct grade & change it soon, you should be fine. I would try to find the right 5-30 cap to be properly reminded ha ha..
    I would recommend the Mopar thermostat & EPDM rad hoses as they fit perfectly and are marked for easy installation. I prefer keeping the OEM spring clamps in use.
    Replace the PCV filter and air filter too.
  3. LibbyLover
    Feb 23, 2020
    The oil change is due in about 3 weeks, and I planned on using the Mopar thermostat, and PCV, air filter, and correct oil cap are also on my list and in my rockauto cart, hehe. I just forgot to add that to my list of replacements because my brain files that under general maintenance with wipers and oil filter...... That's what I get for helping my dad and step-dad play with their sports cars and trucks, respectively, hehe
    LibertyTC likes this.
  4. kejobe
    kejobe Full Access Member
    357
    35
    Sep 5, 2016
    NE Ohio
    I run Mobil 1 5-w20 oil without issue. Have since I bought it 4ish years ago. And I use Mopar filter. Bought with 120,000 miles and have 156,000 now. My cap says 5-w20 also.
  5. tommudd
    tommudd Moderator Staff Member Moderator
    17,568
    328
    They went to 5-20 to try and get an extra one tenth of a gallon more per gallon
    would never run that low, all 3 of mine get 5-30 Mobil 1 full syn
  6. LibbyLover
    Feb 23, 2020
    I'm pulling the "book says 5W-30" card, and just get that kinda oil, hehe. But my parts are ordered and hopefully next weekend I'll be able to get this done in a day
  7. kejobe
    357
    35
    Sep 5, 2016
    NE Ohio
    I seen a decent independent review if the Rotella gas truck 5-w30. I’ve been thinking if giving that a try next oil change. Plus where the wife works I can get a discount in it. :D
  8. LibbyLover
    Feb 23, 2020
    So my parts are showing up a bit earlier than I planned, I know what I'm doing this weekend, lol! I just need to get my oil and a bunch of distilled water and I'll be ready for everything!
  9. LibbyLover
    Feb 23, 2020
    Finally got all my parts on today! Had to add a few extras to fix, like exhaust bolts for the passenger side catalytic and transfer case switch, but I'm saving that for next weekend when I have more time and room in my Baby Jeep. Tomorrow is dedicated to cleaning her out and cleaning her up!
  10. LibertyTC
    6,769
    265
    Also ONLY HOAT coolant for our Jeeps.
    Zerex G-05 comes pre-mixed 50-50.
    [​IMG]
  11. LibbyLover
    Feb 23, 2020
    I have the G-05 in her now, I already knew that because my boyfriend had a Jeep Grand Cherokee that had a cracked radiator a few years ago. We got that fixed and then some buttmunch had to turn it into scrap metal a year ago.....
