rigid
The radiator is 3 years old. New heater core and blend door actuator two years ago. I can hear the actuator cycling. The tank and cap was replaced with the heater core. Barely warm at best. On the throttle it would get a bit warmer, but coming to a stop back to barley warm.
Some suggested water pump may be worn from prior coolant. I replaced it yesterday and the problem is still the same if not worse. The old pump still had the plastic impeller all in tact. When filling yesterday I filled through allen plug and ran it 15 minutes with the funnel still in it and topped off. I drove it 10 miles and then loosened the plug a bit to see small air bubbles come out. Topped the reservoir off and had a bit more heat, but not hot. This morning it would clear the windshield of light frost after 15 minutes. The same issue. At speed warm but nowhere near hot. The minute I'm off the throttle or at a stop sign it is cold. Zerex o5 coolant . Any ideas on what is next?
Thank you
Thank you
