Lifted KJ on 35s
Discussion in 'Post Your Liberty Pictures' started by KJNater, Aug 22, 2014.
  1. KJNater
    KJNater New Member
    Mar 14, 2014
    Missouri
    Finally cleaned my Libby and took some pics. More fabrication to do but it's getting there.
  2. Hedsic
    Hedsic Full Access Member
    961
    Apr 3, 2013
    Des Moines, Iowa
    Looks good. Needs the fender flares back on it though.
  3. John3seventeen
    John3seventeen Full Access Member
    1,324
    Jul 20, 2013
    WV Panhandle
    Tell that to the tires!:emotions34:
  4. Hedsic
    961
    Apr 3, 2013
    Des Moines, Iowa
    Nah! There's plenty of room there still for the flares.
  5. TheBlueKJ
    TheBlueKJ Full Access Member
    1,613
    Oct 29, 2012
    South Jersey
    He's got Tom's rear bumper on there
  6. KJNater
    KJNater New Member
    Mar 14, 2014
    Missouri
    Yeah the flares for just fine in front and rear. Did some cutting and cleaning out of those wells to get the space. That said, I'm thinking of fabricating some smaller metal flares that barely cover the fender area. Then I'm going to bolt them on after line x and roll with those. Looking also to cut about 3" off the bumper wings on each side. Should be an easy mod and give a clean look with better clearance. Always an experiment :) eventually will sell the fender flares too, I think.
  7. TheSurvivor
    TheSurvivor Full Access Member
    88
    Feb 4, 2013
    Grand Island NY / Central Square NY
    Do you have a build sheet? I'm really curious as to what you have done to your jeep it looks awesome!
  8. Dave
    Dave Administrator Administrator Moderator
    15,590
    Looks good.
  9. jeffk82
    jeffk82 New Member
    23
    Aug 23, 2014
    kansas city mo
    I'm about to go jba 6 lift. What is your lift and what all did you have to do on it.
  10. KJNater
    KJNater New Member
    Mar 14, 2014
    Missouri
    Well, thanks! It is getting there. Did a lot to it but the best thing is lift and some wheel well cutting. In the front, you have to take off the factory plastic and cut that metal flare that extends from the uni body out towards the tire. Once that is cut, and a proper lift is in place, you can out much bigger tires in. The front isn't the real issue though. The rear axle position and well space is the challenge. I move the rear axle back an inch and trimmed a lot to get the wheels in there. I have more trimming to do and a JBA 6" lift is, I think, perfect. I took out the anti sway bar (rear axle) and she does well for the road both on and off.
    But to get actual room for flex off road with 35" Tires you have to do more cutting. I'd recommend 33s with what I described to do off roading as you'll get better flex into your wells and probably be happier.
    Hope that's helpful.
  11. KJNater
    KJNater New Member
    Mar 14, 2014
    Missouri
    I went with JBA also. 6" left is perfect too. You can go up or down on the adjust a struts and the package of shocks and front steel diff had been very good. While I'll admit I'm hungry for a SFA, JBA stuff is top notch, I think. He also knows his stuff and if you have questions about the build he's helpful to answer. My recommendation is to get someone with attention to detail on putting that stuff in. The arms have to be cut just right and so on. If you do that, you'll be very happy. He's pricey, but his stuff is very good. I wheeled hard for a week straight on his lift and was anticipating my IFS to give out or break on some of the pinches I was in but it held up very well, no issues. Again, SFA is the better build on my opinion, but if you're ready for a lift, I'm very happy with my JBA. The parts are tough and doing very well so far.
    My work so far...
    JBA 6"
    Adjust a struts
    Bilstein front/rear
    Brake lines
    Tri-Angulated 4 link
    Upper and lower arms
    Steel front diff
    2" drop
    Rear coil springs
    Extended bump stops
    4.5" arms, etc.
    Recommend spacers (helps with spacing tires from arms when u r deflating the tires for off roading)
    That's just a simple list from JBA stuff. there's more that I did with lockers and 4.88 gears and compressor and louvers, etc but have been pleased with JBA.
    I'd definitely get a 6" and not the 4" And I'd recommend lifting the front to even the plane for the rear lift. Usually a Libby has about an inch more lift on the rear than the front but I evened up the front with the rear and she rides much better. Just a suggestion.
  12. CactusJacked
    CactusJacked Full Access Member
    2,409
    Dec 12, 2013
    Chicago Suburbs
    What did you use to move the rear axle back an inch?
  13. jeffk82
    jeffk82 New Member
    23
    Aug 23, 2014
    kansas city mo
    See I did have 285 75 16 on mine so I already and knocked on pinch and rear is about 2 inch farther back
