lift kit for the nitro, will it work on the new lib
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
Heh....
a KJ lift kit will work for the Nitro.
a Nitro lift kit will work for the Nitro.
a KK lift kit will work for the Nitro.
The suspensions are for the most part, identical in all the necessary areas, the only difference is a new knuckle.
Jeepman56
Green Bay, WI
:confused: A KK I understand as it is intended for off road, but why a Nitro? Do people wheel Nitros?
Diggerfreek
Colorado
i lift for a kj would work for a kk but the ubj is offset at the wrong angle..you could put the lift on, but it would wear out the ubj really fast
Marlon_JB2
Kombat Edition Jeep
Wow! The KK Looks way better than the KJ when no longer at stock height! But just like the KJ... that's the way it *should* have looked from the factory.
yoda13
Texas
I thought the Nitro lacked the availability of low range....?
Any lift for the KK that does not include new brake lines and a adjustable(or longer) rear trackbar shoild not be used.
The stock brake lines are barely long enough for the stock suspension,adding any lift will stretch the brakes lines and they can and will fail,re-routing of the rear ABS sensor lines in needed also.
Myself and RockLizard have test fitted a Frankinlift on a KK and at full droop with the stock suspension the brake lines were about as tight as bango springs.Also without a adjustable rear trackbar(or longer one) the rear axle will be shifted to one side after lifting.
JBA is working on a 4"(and 2.5") lift for the KK that will be complete,not cheap but it will be complete with all needed parts,just waiting and the rear brake lines and we'll be test fitting one on a KK sometime real soon.
Exalype09
United States
lift kit for the nitro will it work on the new lib
hey
im just getting into the whole 4x4 thing and i need some help on what type of lift kit i should go for? any help
cheers
One from a nitro will work...OME springs are preferred, or a JBA lift, which might use OME springs.
Diggerfreek
Colorado
We need some more info on how you want your KK to look and what how much money you are looking to spend.....
