mindbomb
Given the car is on flat surface and steering is straight must I lift the car before replacing the sway bar bushings? (and end links?)
No. But will make life 1000X easier.
Why bother trying to get to the end links with the tire still on? Seems like an unnecessary hassle to me, I'd just do one sway bar link at a time, then drive it onto ramps to do the bushings.
For the links, you'll likely need to jack up on the LCA to make the bolt holes line up once you've taken the old away bar link off.
So I don't have to lay on the ground lol.
Never had to turn the wheel at all to do mine?
