KJ Sunroof bringing the rain - Manual Override Question? 2002 - 2006 KJ
Muddy1
TLDR: Anybody ever turned a flathead in a secret spot to move the glass back manually?
“After the rain”.. as they say. The practical jokers in the engineering department have the clogged drain holes reroute water into the interior fuse panel, resulting in the vehicle now being powered by Grrrr.
Sunshine, time and a blow dryer may help, but until then, it seems no coincidence that this was followed by erratic horn beeping and a new inability of the windows and sunroof to operate under their own power.
Looking online, we found that the artificially intelligent suggest the following:
If your Jeep KJ sunroof is not functioning due to a power issue, you can manually open it using the following method:
Steps to Manually Override the Sunroof Motor​
  1. Locate the Sunroof Motor:
    • The sunroof motor is typically found in the headliner area above the sunroof.
  2. Use a Flathead Screwdriver:
    • Find the manual override mechanism near the sunroof motor. This is usually a small slot or gear.
  3. Turn the Manual Override:
    • Insert the flathead screwdriver into the slot and turn it gently. This should allow you to open the sunroof manually.
Important Notes​
  • Ensure that the area around the sunroof is clear of any obstructions before attempting to open it.
  • This manual method is a temporary solution until the power issue is resolved.
By following these steps, you can successfully open your Jeep KJ sunroof without power.
So, HAS ANYONE DONE THIS?
( not yelling, sorry, just changing gears )
If so, can you share any pics?
Also, once wetness stops windows and sunroof motor operating, will it self heal after drying out? I have found no bad fuses yet.
Thank you
