Just bought a Frankenlift ii premium lift
linkfalcon
Nothern va
Frankenlift II Premium Kit for GAS KJ: $1,219.99
Comes with pre-assembled front struts assemblies. Uses OME H/D 90009 Sport Series Front Struts, OME927 H/D front Springs, Proprietary Poly parts, Strut Top Plates, All hardware needed; Rear OME948 H/D springs, OME132L Rear Long Travel Shocks (SEE NOTE ABOVE) and pair of rear extended bump stops. Plus, 1 Frankenlift Decal.
So I just bought the kit got front stuff used what else's should I replace while in there the old owner had control arms installed and I also order the kj1/2 spacers for rear
Anything else I should order
wheeee32
Not the mountains.
Wait, so you have the used front and the the whole new kit in it's entirety? All you need for the rear, other than the springs and struts, is 1 iso per side to put on the top of the springs. You can use the bump stops for the rear that come with the kit, but two hockey pucks per side work better. You'll need the terra flex bump stops for the front also.
linkfalcon
Nothern va
Oops sorry lol I order just the rear and got the front used sorry
wheeee32
Not the mountains.
Ah okay. Yeah just get an upper rear iso for each side and go with the bump stops provided for the rear or bolt in your own hockey pucks (2 per side). For the front bump stops, cut a notch in them should you decide to eventually put jba upper a-arms on. I have pics posted in the thread with my jba adjust-a-struts installed.
linkfalcon
Nothern va
Should I use the 1/2 inch ones or double up on stock ones
Cool thanks guys the rear looks easy
Front is as well since you have a Frankenlift
Get up eat breakfast, install the lift, drive downtown at lunch time for an alignment and lunch
