JBA wheels?
Discussion in 'Tires / Wheels' started by Sephiroth, Nov 15, 2018.
  1. Sephiroth
    Sephiroth Full Access Member
    123
    Apr 10, 2012
    New Mexico
    I've been looking at the wheels from the JBA website, Baja 16x8 I'm currently running the OEM steel wheels with 245/75/16 tires and have a small amount of rubbing at full lock when in reverse with the OME lift, top plate, and clevis. can I fit this wheels without any major problem? and can I use the same 245/75 tires on an 8" wide wheel?
    if I understand correctly the Bajas have 1 in less backspace than stock and a 0 offset vs 41mm which means that the tire would come out about 2"? anyone running this wheels? any better options?
  2. tommudd
    tommudd Moderator Staff Member Moderator
    17,204
    193
    A proper 8 inch wheel should have 5 inches of backspacing
    Anything less will sit the tire and wheel out further
    245-75-16s will work, BUT I run 16 X8 with 5 inches of backspacing and 265-70-16s ( same height as 245-75-16s ) and they sit on the wheels much better. With over 8 inch tread width way better than 7 inches of tread width
    Now on to the next thing yes there will be some rubbing possibly depends on how much lift you have
  3. Sephiroth
    123
    Apr 10, 2012
    New Mexico
    So look for something with 5 inches of backspace, got it.
    Sent from my SM-G955U1 using Tapatalk
  4. tommudd
    17,204
    193
    IF lifted 7 inch wide with 4 inches of backspacing works great sits the tire/ wheel combo out to edge of flares but allows you to run a conventional tire like 245-75-16 etc
    Going 8 inch wide 5 inch backspaced , you should run a wider tire like 265-70-16 when lifted
  5. Sephiroth
    123
    Apr 10, 2012
    New Mexico
    I do plant to go with 265/70 eventually, I just wanted to make sure I can continue to use my current set 245/75 till I'm ready for new tires. Planning on getting 4:10 gears as well just not sure if before or after the tires.
