Thanks for the reply. Believe it or not, I've read the FAQ along with countless other threads over the past 2 weeks. Just still have some questions I'm unsure of.
Regarding the hockey pucks in the rear, are there other options for rear bumpstops? Since I'm getting this lift professionally installed, I'd rather purchase actual bumpstops as opposed to hockey pucks. The money is not a problem.
If they can not look up labor for replacing front/rear shocks and rear coils,which is what is being done,then time to find someone better qualified to install the lift.It's really a 2 hour job at most,2.5 hours of actual labor if you have to disassemble the front coilover and reassemble them.Those times are from doing this in a driveway with no power tools besides a cordless 1/2" drive impact.I'm going to be ordering the OME 927/948 lift kit from JeepinByAl.com here in the very near future. I'm going to have to get installed professionally as I am not very mechanically inclined and I currently live in an apartment so do not have access to the necessary tools.
When calling around to different shops, many said they would need to read over the lift kit instructions before quoting me for the labor. This got me thinking.. does the OME lift kit from JBA come with instructions??
My order is as follows:
-OME 1.50" lift kit x1
-TeraFlex Bump Stop x4
-Strut spacer plate set x1
-Rear upper coil spring isolator x2
Is there anything I'm overlooking here?
Agreed.In all honesty, if the shop needs instructions, you may need a new shop.
Are you getting the 132L rear shocks or standard length?
Are you doing a clevis lift as well as top plate, if so you need two more top iso's for the rear
Would that not be 4 per side 3 on top and one one the bottom or maybe 2on top and 2 on the bottom?
where at in md are you located? im in severn and i lifted my liberty with me and my father inlawn. i may be able to lend a helping hand if needed. just installed my JBA a arms. which your going to also want soon.
