Jba 4 link vs IRO wj rear a arm
JJam2112
Port Angeles, WA
Hey Guys, I’m curious to the pros and cons of the Jba 4 link vs IRO wj rear a arm. Has anyone tried both and what are your experience. How is handling and noise?
Both about the same as far as handling, I run the JBAs on my 03 and 04 , some complain about noise, but if you clean them and spray them with lube every now again no noise at all
I have about 75-80,000 on one set, 50,000 on the other
But JBA is no longer available so guess what is left, yep, trying to find someone to make the bracket for the IRO, good luck
JJam2112
Port Angeles, WA
thanks Tom. JBA has one more of the bolt on and I found a guy making the mount. Debating which one to go with. Do you have the bolt on or the welded version?
Bolt on, have the very first preproduction one on the 04, was a tester, test did so well still one there
compare prices of everything
last I saw one guy making the brackets he wanted arm and a leg, then had to buy the IRO on top of that
JJam2112
Port Angeles, WA
The guy who made them told me $170 shipped. I’ll have to call IRO and see how much they can do the a arm since I don’t need the bracket.
u2slow
BC
There's a number of simple truss options for well under $170.
Has anyone inquired if IRO will sell the truss part off their WJ axle swap bracket kit together with the arm?
JJam2112
Port Angeles, WA
That would be a interesting option worth looking into. Wonder if anyone has done it
u2slow
BC
The IRO arm comes with WJ bracket. Its a flat 3-bolt top-mount that would be easy to re-create on a truss.
Oh look. ECGS figured it out
LOL well here I thought we were talking BOLT ON, not WELD ON, see this is what happens all the time
talking apples and eggs , completely different
both round sort of but that is about it
