It appears parts geek has one.Please, I need help. I have been needing to replace the intermediate shaft in a 07 Liberty for almost 2 years now. I am not sure if it’s due to COVID, but I can’t get my hands on one. I’ve tried crown, mopar, every off brand there is. Nothing listed on eBay and the local junk yards have ones worse that what’s on mine now. anything I find online will allow me to order and shows I can order, however just to get an email an hour later saying it’s no longer produced.
will the intermediate shafts from a 2008 and up fit?
2007 part number- 5066057ab
2008 and up- 68019326aa also seen 52114570ab
Thanks, I don't think he's had the intermediate shaft out to prove it's either it, or the diff bearing you mentioned. It's just it seemed this is a common enough problem, that he should be getting prepared for it. Would there be evidence of a leak if it were that?That shaft itself can't really whir. The bearings do not ride on the shaft.
What usually happens is the spline wears and the inner CV hops up and down making a knocking noise. And also found that causes the CV and the shaft to be inseparable - so you need both.
There are bearings inside the very ends of the front diff housing. Those could be expiring. I found it easiest to pull the diff out and do it on the bench.
