Information
Discussion in 'KJ General Discussion' started by XWrench3, Oct 17, 2020 at 1:50 PM.
  1. XWrench3
    XWrench3 New Member
    26
    Sep 30, 2020
    how do i determine if my rear axle has a "posi ,sure grip, or any number of other names) in it without opening the axle cover or purposely trying tp spin the wheels (which is a terribly inaccurate way of testing) ? is there a tag on the axle, or a build sheet someplace i can find all the little things that make a difference? I HATE using profanity, but i am not sure how to say it without using it. "GM" (sorry!) has a sticker in the glove box with all the components. my Liberty does not have one. and I'm not sure if it should. but that type of information would be very handy.
  2. tommudd
    tommudd Moderator Staff Member Moderator
    18,264
    562
    They came with a tag on the axle but assume it is long gone
    Many sites will get your build sheet for you free which tells ya everything
  3. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    7,337
    479
    X2 ^
    You can online enter in your VIN#
    See if it mentions "Trac-Lok" under rear axle. If it has a Trac-Lok you need to add a 4 oz bottle of Mopar Limited slip additive # 0431806AD to the gear lube. Dino is best not synthetics.
    See owners manual for gear lube specs.
    Build sheets here: https://www.jeepkj.com/threads/build-sheet.64657/
    tommudd likes this.
  4. Billwill
    Billwill Full Access Member
    1,734
    264
    Nov 26, 2009
    White River, South Africa
    Yeah my 2002 Export CRD has "Trac-Lok 4.10" on the rear axle.
    I always fill it up with Dino oil and the Mopar Friction Modifier!
