Jeep liberty 2003
Removing blend door actuator
Will need aviation snips like these
& a long straight one
Remove passenger glovebox, and upper plastics, and then the airbag.(make sure negative removed from battery and let sit for a couple minutes before removing to discharge it)
Should have clear view of the actuator now. Then start cutting the plastics with the snips, up until shown in picture 1, be careful not to cut the actuator plug in wire.
After removing all that plastic, should be enough room to unhook the wire from the old actuator. You may now test your new actuator now and let it hang from the dashboard
Remove the 2 screws at the front of actuator(only 1 left now at the back)
Next forcefully using flathead screwdriver, break the front tab holding it(there are 4 in total, in front and one each side).
Next, Should be able to pry up on the small opening in the halves it makes and this prying up should break the other tabs
Top half of actuator should be free now, push it to the back
Next remove all the little gears and stuff with cutting or pulling tools.
Once you cleared out all the little pins and top gears, should only be left with one gear and a metal pole in the middle of it. Cut that metal pole with snips,
Next, using a flat screwdriver as a pry bar, pry up from behind the actuator plastic right in front of the last screw, it should snap. Just pry up against it using the top of the dashboard as leverage. Repeat until last screw is fully accessible with a 8mm wrench.
Remove screw, pull out the bottom half of the actuator
Next the new actuator wont fit as is, will need to cut 1/8 of metal stem to fit. I used a small hacksaw.
Once done, line up the stem from the actuator and the door blend entry hole, as they can only fit in one way.
Reconnect black terminal to battery as seating the new actuator, you will need power
turn on the key (not fully running) , just with power,
Set temp to cool, and the new actuator stem will be turning,
and when the stem lines up with the entry hole, quickly shut off the power, so it stays lined up
Insert new actuator, and put in the 2 front screws(last screw at the back not needed)
