How to unplug ecm?
tvandmoviecars
Michigan
how do I unplug the plugs from the ECM I pulled the red Clips back I try to pull a plug but it doesn't come out is there a trick I am not seeing?
Lancer
South East London
Be very careful, there could be corrosion in there. I'd give it a soak with WD40 or the equivalent first.
kejobe
NE Ohio
Not sure on the ECM, haven't looked, but normally the red clips are just to prevent the lock tab from coming loose. Still need to depress that to undo the plug.
turblediesel
memberable
Alaska
Foggily remembering the locks keep getting pressed and they act as cams pushing the connector off.
