HOW TO: Change your Power Steering fluid
Discussion in 'How To' started by jeepkj02, Apr 14, 2007.
  1. jeepkj02
    jeepkj02 Full Access Member
    1,021
    Mar 25, 2005
    Holland, Michigan, USA
    Time Needed: 30-45 minutes
    Items Needed:
    • Turkey Baster
    • 2 quarts of Power Steering Fluid or ATF+4 (check your owner's manual)
    Steps:
    1. Remove power steering cap and remove as much fluid as you can with the turkey baster.
    2. Pour in new fluid into the power steering reservoir and screw cap back on and start engine. Turn the steering wheel lock-to-lock for a few minutes. (About 10-15 times) Do not stop between turns.
    3. Turn engine off.
    4. Repeat Step 2 and 3 until you finish the first quart. This is to get as much of the old fluid out.
    5. Finally, pour in your fluid one last time until it reaches the "hot" line on the power steering reservoir.
    6. Your finished. Repeat every 7,500-10,000 miles.
  2. richre1
    richre1 Full Access Member
    55
    Apr 11, 2007
    RHODE ISLAND
    But That Doesnt Get All The Fluid Out?? What Bout The Rack
  3. tjkj2002
    tjkj2002 Full Access Member
    10,612
    Dec 17, 2006
    That's why you turn the wheels from lock to lock for a few min,it circulates the fluid from the pump to the PS pump.
  4. SavageUrge
    SavageUrge New Member
    21
    May 18, 2007
    Rochester, NY
    My question is: How in the heck are you supposed to get the cap off? There is no way for mine to come off because it is trapped underneath part of the windshield cowl and a wiring loom. I can get to it enough to loosen it, but I can't get it off to access the fluid.
  5. jeepkj02
    1,021
    Mar 25, 2005
    I don't know if they changed anything post-2002, but mine is near the battery to the right of the serp belt. Care to post a pic? There was plenty of room to remove the cap and suck out/fill up the fluid.
  6. Marlon_JB2
    Marlon_JB2 Kombat Edition Jeep
    15,019
    45
    Nov 20, 2004
    Clinton Township, MI
    It was the same on my 2004... and my sister's 2005.
  7. tjkj2002
    10,612
    Dec 17, 2006
    The PS pump is in the same place on al KJ's from '02-'07(CRD's not included).Do you know where your oil filter is? If yes then the PS pump is right above it,it has a white plastic resivoir and a yellow plastic cap.You must be trying to remove the tranny dipstick if it is by the firewall.If you don't know where your oil filter is you will see the PS pump just to the left and a little down from the battery,also a little under the upper radiator hose.If you don't know where the battery is or the upper radiator hose is take it to a shop cause you shouldn't be under the hood.This is only for gas KJ's.
  8. SavageUrge
    21
    May 18, 2007
    Rochester, NY
    OK, thanks. I am quite familiar with the oil filter so I shouldn't have a problem locating it. As for what I was attempting to remove the cap on, it is located just underneath the wiper cowl in the far right corner of the engine compartment (if you're looking at it head on). What is this round reservoir? I'll try to get a pic of it if you can't find it. I have a manual tranny so I don't have a dipstick.
  9. tjkj2002
    10,612
    Dec 17, 2006
    The only 2 reserviors next to the firewall is the coolant overflow(left side) and the brake master cylinder(right side),since you have a manual then you will also have the clutch master clinder on the right side,that must be what you are trying to open.
  10. AlexKJ
    AlexKJ Full Access Member
    315
    Nov 16, 2007
    Earthquakeland
    Related TSB
    Steering - Power Steering Fluid Usage
    NUMBER: 19-005-03
    GROUP: Steering
    DATE: Aug. 29, 2003
    THIS BULLETIN SUPERSEDES SERVICE BULLETIN 19-007-01, DATED AUG. 2, 2001, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
    SUBJECT:
    MODELS:
    1993 - 2003 (AB) Ram Van
    1994 - 2004 (AN) Dakota
    1994 - 2002 (BR/BE) Ram Pickup
    2004 (CS) Pacifica
    1998-2004 (DN) Durango
    2002 - 2004 (DR) Ram Pickup
    1996 - 2000 (GS) Chrysler Voyager (International Markets)
    1995 - 2000 (JA) Cirrus/Stratus/Breeze
    2001 - 2004 (JR) Sebring Sedan, Stratus Sedan1 Sebring Convertible
    1996 - 2000 (JX) Sebring Convertible
    2002 - 2004 (KJ) Liberty
    2002 - 2004 (KJ) Cherokee (International Markets)
    1993 - 2004 (LH) Concorde/Intrepid/Vision/LHS/New Yorker/300M
    1996 - 2000 (NS) Town & Country/Voyager/Caravan
    2002 (PG) Chrysler PT Cruiser (International Markets)
    1995-2004 (PL) Neon
    1997 - 2003 (PR) Prowler
    2002 - 2004 (PT) Chrysler PT Cruiser
    2001 - 2004 (RG) Chrysler Voyager (International Markets)
    2001 - 2004 (RS) Town & Country/Caravan/Voyager
    1993 - 2002 (SR) Viper/Viper Coupe
    2001 - 2004 (ST) Sebring Coupe/Stratus Coupe
    1997 - 2004 (TJ) Wrangler
    2003 - 2004 (VA) Sprinter
    1999 - 2004 (WG) Grand Cherokee (International Markets)
    1999-2004 (WJ) Grand Cherokee
    2003 - 2004 (ZB) Viper
    2004 (ZH) Crossfire
    DISCUSSION:
    The factory fill power steering fluid for most 2004 model year Chrysler Group vehicles is ATF+4 (MS9602) and it provides superior performance at both low and high temperatures. WJ/WG and ZH vehicles use unique power steering fluids. Refer to the table to identify factory fill and the approved service power steering fluid by year and model. Note that MS9602 is Red in color and MS5931 and MS9933 are Amber/Yellow in color. All three fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
    The part numbers for MS9602 are 05013457AA (quart) and 05013458AA (gallon). The part number for MS5931 is 04883077 (quart). The part number for MB345 is 05127381AA.
    MS9602 should not be mixed or used as a "topping off" fluid on systems requiring MS5931. On some past models, MS9602 should be used as the replacement fluid. On these models, if a power steering system is being serviced that results in a large fluid loss, such as a pump, hose or gear/rack replacement, the complete system should be drained and filled with MS9602.
    NOTE :This bulletin supersedes owner's and service manuals for the vehicles listed above that may state to use MS9933 in the power steering system, and that may state not to use automatic transmission fluid in the power steering system.
  11. AlexKJ
    315
    Nov 16, 2007
    Earthquakeland
    Here is an alternate method
    These are the materials: A 60cc syringe (I brought this one in a drug store) and a section of plastic tubing (I found this one in a hobby shop. It intended use is for pouring fuel to RC toys).
    [​IMG]
    Considering that my KJ was manufactured before 2004, it has power steering fluid instead ATF+4.
    [​IMG]
    The power steering fluid reservoir cap is in the yellow thing in the center of the picture.
    [​IMG]
    Here the reservoir is open.
    [​IMG]
    Here is a picture of the syringe extracting the old power steering fluid.
    [​IMG]
  12. hyde
    hyde Moderator KJ Supporting Member
    7,380
    Feb 15, 2006
    Cool, I like that syringe! :) Makes it much easier.
  13. hyde
    7,380
    Feb 15, 2006
    So 2 quarts is enough to fill it up?
  14. jeepkj02
    1,021
    Mar 25, 2005
    It really one takes about 1/4 qt to fill it up. The 2 qts are to flush out the old fluid.
  15. hyde
    7,380
    Feb 15, 2006
    Yep, that's what I am going to do, since I don't know what they've put there previously. I bought myself some tubes, and a turkey baster, will suck them out and replace, so 2 qts will be enough, right?
  16. Tokyojoe1965
    Tokyojoe1965 Full Access Member
    390
    Nov 20, 2004
    Denver Metro, CO
    At what point do you know you have sucked out all of the old stuff? Complete color change so that it looks exaclty like the fluid you poured in?
  17. hyde
    7,380
    Feb 15, 2006
    I tried to suck as much as possible, no way. I bought similar tubing, but that tube is not going in all the way in. So I just sucked as much as possible and just dumped the new one in. It was enough to smoothen the steering and the nasty grinding noise was gone.
  18. KJ04
    KJ04 Full Access Member
    182
    Mar 4, 2005
    Grafton, Ohio
    A plastic hand pump, from the auto parts store used to pump gear oil in to your front and rear differentials would be a quicker way to remove the fluid than using a turkey baster.
  19. ShafferNY
    ShafferNY Full Access Member
    641
    Dec 1, 2007
    Ticonderoga, NY
    BODY:KJ
    YEAR:2002 - 2004
    FACTORY FILL POWER STEERING FLUID:MS9602
    APPROVED SERVICE POWER STEERING FLUID:MS9602
    http://dodgeram.info/tsb/2003/19-005-03.htm
  20. Dave
    Dave Administrator Administrator Moderator
    15,590
    I like that syringe that Alex is useing.........hmmmmmmm. I might just have to scrounge up one of those.
