ENGINE OIL CHANGE
Change engine oil at mileage and time intervals described in Maintenance Schedules. Run engine until achieving normal operating temperature.
(1) Position the vehicle on a level surface and turn engine off.
(2) Remove oil fill cap.
(3) Hoist and support vehicle on safety stands.
(4) Place a suitable drain pan under crankcase drain.
(5) Remove drain plug from crankcase and allow oil to drain into pan. Inspect drain plug threads for stretching or other damage. Replace drain plug if damaged.
(6) Install drain plug in crankcase.
(7) Remove oil filter - All engines are equipped with a high quality fullflow, disposable type oil filter. DaimlerChrysler Corporation recommends a Mopart or equivalent oil filter be used.
(7.1) Position a drain pan under the oil filter.
(7.2) Using a suitable oil filter wrench loosen filter.
(7.3) Rotate the oil filter counterclockwise (Fig. 73)to remove it from the cylinder block oil filter boss.
(7.4) When filter separates from cylinder block oil filter boss, tip gasket end upward to minimize oil spill. Remove filter from vehicle. NOTE: Make sure filter gasket was removed with filter.
(7.5) With a wiping cloth, clean the gasket sealing surface of oil and grime.
(8) Install a new oil filter.
(8.1) Lightly lubricate oil filter gasket with engine oil.
(8.2) Thread filter onto adapter nipple. When gasket makes contact with sealing surface, (Fig. 74)hand tighten filter one full turn, do not over tighten.
(9) Lower vehicle and fill crankcase with 5 quarts of the specified type of engine oil described in this section.
(10) Install oil fill cap.
(11) Start engine and inspect for leaks.
(12) Stop engine and inspect oil level.
As a side note, if you have a skid plate installed, ensure that no oil has spilled onto the top of it. Cleaning with a utility towel should do the trick.
First Oil Change on a New Vehicle? The filter is really tightened from the factory. Like REALLY tightened. You might consider having your first oil change done @ your friendly Jeep dealer.
