How to change oil pan gasket easily?
libordemise
CA
I tried posting a few times and don't know where they went haha!
In sure I read somewhere there is an easy way to replace the oil pan gasket in these where you don't have to pull the engine or cut through the frame or cross member? Jk.. Mostly...
Sent from my LG-K210 using Tapatalk
No real " easy way"
some have been able to lift the engine enough and drop the pan enough to get in there and unbolt the pickup, but basically working blind
Don't ever joke about cutting into the frame, etc only an idiot would do that
libordemise
CA
In reading one could undo the three bolts that hold an assembly in from between pan and block them remove pan without moving engine??
I wouldn't cut frame ;) but I'm not saying I'm not an idiot bahaha
