Highlighted posts from Tuesday, Sep. 13, 2022
JeepKJNewsletter
Click here to view on the web
Highlighted posts
September 09, 2022 * 10 posts * 215 views
JRB said: Did they ever make oem metal tail light guards for the kj? At the junkyard hunting renegade flares, I noticed a 2003 had tail light guards on it. I got really excited to see them ... Read more >>
September 12, 2022 * 7 posts * 132 views
mertz019 said: Hey all, this is the first time I am lifting a Jeep and i'm nervous about it. Fortunately, i'm doing it at a place with all tools needed including Spring Compressors, Ball Joint ... Read more >>
September 10, 2022 * 11 posts * 235 views
first&lastKJ said: I just noticed today that the front passenger side axle seal is leaking. Any tips on removing the seal? It looks like the seal is recessed in the axle tube two or three inches. Read more >>
September 08, 2022 * 8 posts * 200 views
Patrick McGrinder said: 2007 jeep liberty,the circled part in the picture. Thanks ! [image] Read more >>
September 08, 2022 * 5 posts * 165 views
2mJps said: I have a 11 - 05 liberty that hit a deer. My liberty has fog lights in the grille. A scrap yard not a parts yard had a 2005 dont know the month that i got a radiator, inner grille, ... Read more >>
September 12, 2022 * 3 posts * 104 views
davestar said: Hi everyone, im new here, so please forgive me if I have done wrong. I have a jeep Cherokee KJ 2001 limited (European spec) as I'm from the United Kingdom. In the USA you call ... Read more >>
September 06, 2022 * 13 posts * 730 views
CRD28 said: Right depending on how much of the old key is sticking out. There's a button on the key side turn the key to lock and press the button to release the key. If it's on the blade ... Read more >>
September 13, 2022 * 2 posts * 49 views
EricNorton said: I have a 06 gasser so there's probably a significant amount of spring droop I will measure the stance of 4 corners in a day or two. I currently have 245 75 r16s and a two-inch ... Read more >>
September 06, 2022 * 8 posts * 470 views
Hermics said: Mine broke when I replaced my struts. I went to my parts store picked up a few feet of heater hose then went to Home Depot and picked up a T-fitting from the plumbing section. ... Read more >>
September 08, 2022 * 3 posts * 129 views
Midwest
mijinchy said: Hi to everyone! I bought a 2008 Jeep Liberty Sport on 12/2020. After a few months of using it, I started getting the "Check Engine" light with the "gas cap" description, and the ... Read more >>
Continue reading...
