JeepKJNewsletter
- Joined
- Mar 31, 2021
- Messages
- 74
- Reaction score
- 0
Click here to view on the web
Highlighted posts
May 30, 2022 * 7 posts * 121 views
liron sasson said: Here in israel we dont have napa so we found local axle shop that can repair the movment between the cx axle and axle shaft. What do you think? Read more >>
May 30, 2022 * 4 posts * 88 views
Ikster said: I removed the shock struts on my 2005 Liberty Limited 4wd in order to replace the shock absorbers. It has a 2" lift kit installed. I was able to find a shop that could disassemble ... Read more >>
May 28, 2022 * 34 posts * 1,050 views
Shankster said: From my experience you should go with the JBA or RRO upper front control arms. Don't throw away your money on labor and parts for new stock type control arms - when lifted, the ... Read more >>
May 27, 2022 * 6 posts * 310 views
Elliott said: Thinking about getting front and rear lockers. This is my daily driver with weekend fun thrown in a few times a year. Would the DTT for the front be fine with the selectrac? I ... Read more >>
May 30, 2022 * 5 posts * 95 views
penst8grad said: Hi, 1st post. I'm looking for a CRD Liberty for my daughter. I found one that has me interested enough to look at it. Seems well kept and the owner recently changed timing belt ... Read more >>
May 26, 2022 * 5 posts * 282 views
Jeff Jot said: '04 6 cyl Jeep Liberty with around 80K miles. Two days ago suddenly a rattle started, though it kind of comes and goes. After getting an oil change, the Jiffy Lube tech (excuse ... Read more >>
May 25, 2022 * 16 posts * 471 views
gmckinney_usmc said: Hey yall. I have a 2003 jeep liberty renegade. I'd like to level it while also replacing worn suspension components. Don't need or want a full on lift. Was wondering if anybody ... Read more >>
May 24, 2022 * 11 posts * 391 views
Wendy Vazquez said: Can someone please guide me as to where the heck the motor mounts are on an 03 KJ.. I've searched everywhere and no clear answers. Also would a broken motor mount cause a clanking ... Read more >>
May 28, 2022 * 5 posts * 150 views
Jj231 said: An update to a previous post. The first problem I had is with a failed cam ps. I changed the sensor twice and it cures the problem for about a week. Then the good ole p0340 returns ... Read more >>
May 25, 2022 * 8 posts * 333 views
Ben Paka said: I love this site already. I have a question, I cant seem to find the correct length to the rear driveshaft on my 2005 Liberty Renegade. does anyone know the exact length? looking ... Read more >>
Continue reading...
