Highlighted posts from Tuesday, Jun. 28, 2022
JeepKJNewsletter
Click here to view on the web
Highlighted posts
June 25, 2022 * 21 posts * 389 views
Deb'nKJ said: So the RH axleshaft did need replacing (because it had started clicking when turning - & there was definitely play in the CVJ) but it's not cured the knocking which prompted me ... Read more >>
June 25, 2022 * 16 posts * 365 views
bench10 said: Hey guys first time posting but i have been here in the forum for awhile, decided to ask here since I've found a lot of good info when i wanted to lift my Jeep (2.5 OME Lift) , ... Read more >>
June 22, 2022 * 21 posts * 556 views
How To
Burnzomatic said: Thanks , though it does feel like its coming from passenger side , this part is under drivers side but its an idea . i have checked that part several times boot is fine just to ... Read more >>
June 26, 2022 * 4 posts * 133 views
1Done&Home said: I want to install a large trans cooler in my wife's pristine 2003 Liberty that I bought new for her 19 years ago. I think I'm ok but I believe that two heads are better. That's ... Read more >>
June 27, 2022 * 5 posts * 115 views
Falcor31 said: The car has 118k miles, it's a limited 4x4, car will be used as a daily driver in the city, and will rarely see dirt, comfort around rough roads is the goal. Already ordered the ... Read more >>
June 22, 2022 * 11 posts * 812 views
eldredg said: Only thing I would comment is that you might lose a fraction of a MPG in fuel usage by removing the air dam. And it is said by some that your engine cooling may be slightly less ... Read more >>
June 26, 2022 * 11 posts * 306 views
JeepJeepster said: Very nice! To answer your question, yes, its normal for coolant to immediately flow out of that hose. While the bleed screw is needed on other configurations, its not as important ... Read more >>
June 23, 2022 * 6 posts * 237 views
matt&marshaSDuff said: Aftermarket bumpers that are built good with sick looks for a 05 KJ Renegade are over a grand easily. Now on the other hand if you were looking for bumpers for a JK, Rub, or TJ ... Read more >>
June 27, 2022 * 2 posts * 45 views
KKinTexas said: I have problem that keeps occurring about every 6-9 months. I have to replace the recirculation actuator behind the glove box because it starts to malfunction which sounds like ... Read more >>
June 27, 2022 * 2 posts * 82 views
bostonjeepfam said: what v8 engines are compatible with a 2012 liberty latitude 3.7 v6, should i upgrade the trans (or anything else) on it as well? if so please share. would like to make it track ... Read more >>
Continue reading...
