Highlighted posts from Tuesday, Jun. 21, 2022
JeepKJNewsletter
Click here to view on the web
Highlighted posts
June 20, 2022 * 6 posts * 99 views
JasonTheOverlander said: After repairing a dent in my front bumper with the old boiling water trick, I decided to remove the black plastic air dam which sits just below the bumper. I had to break a few ... Read more >>
June 18, 2022 * 9 posts * 388 views
Deb'nKJ said: Thought it was time to move on from my introduction, as this might well be the beginning of the end - so far as this KJ is concerned. Wouldn't normally call it quits this time ... Read more >>
June 19, 2022 * 5 posts * 199 views
How To
runfor5 said: Happy Saturday. Seen some posts on bump stops but pictures were lacking. And YouTube only has the fronts. Here are some photos for ease for anyone in the future so you can confidently ... Read more >>
June 20, 2022 * 6 posts * 135 views
GR5000 said: I have a 2012 Liberty with the Mopar skids (radiator, engine, transmission, xfer case, and gas tank). I recently got back from a offroad / camping trip and inspected my undercarriage ... Read more >>
June 15, 2022 * 7 posts * 322 views
Osorkonius said: Hey all, While deattaching side pillars to pull a DAB antenna underneath in my 2005 KJ, I've noticed an unused socket. Does anyone know what's its purpose? [image] Read more >>
June 14, 2022 * 21 posts * 971 views
soulpunisher said: Take the oil cap off and see if it's milky color and dipstick. Same with transmission dipstick Check to see if when started white smoke comes out of exhaust the whole time it runs, ... Read more >>
June 18, 2022 * 4 posts * 105 views
Fri501pmkk said: Reading some good info on this product...thinking of getting it and adding to engine and transmission....just curious if anyone uses it and if any pros or cons... Read more >>
June 15, 2022 * 8 posts * 349 views
Jaybird91 said: Hello i would like to know which way are the two small peices of hardware should be facing while assembling the coil over set. I took everything to a shop and want to make sure ... Read more >>
June 17, 2022 * 3 posts * 173 views
lfhoward said: [image] What would you put on your KK if you needed a muffler, tail pipe, and resonator? The options in the poll seem to be the available ones. I would totally go with a Magnaflow ... Read more >>
June 20, 2022 * 3 posts * 92 views
runfor5 said: Recently asked about the grey color code for bumpers and fender flares, in the meantime I repainted the plastic black grille insert on my Sport trim. Had never used the below SEM ... Read more >>
Continue reading...
