JeepKJNewsletter
- Joined
- Mar 31, 2021
- Messages
- 86
- Reaction score
- 0
Click here to view on the web
Highlighted posts
July 20, 2022 * 20 posts * 438 views
duderz7 said: Be patient and vigilant. Took about a year and a half, but finally got a set for $300, low miles, spare had never been on the ground. Sold tires for $200 if memory serves. Let ... Read more >>
July 23, 2022 * 13 posts * 440 views
Techdad said: Check your belt and tensioner. If your belt is glazed or the tensioner is weak, there can be enough slippage to allow a wet belt to slip around the A/C pulley without turning the ... Read more >>
July 19, 2022 * 7 posts * 207 views
Billwill said: I have maybe been incorrect about my posts as regards the Curved Flywheel on the manual KJs. This I now think this may only be relevant on the CRDs that have the Manual Gearbox ... Read more >>
July 22, 2022 * 3 posts * 116 views
RexSmith said: Hi all, My daughter's 2006 Liberty (appx 250k miles) has intermittently had the battery light come on... (She lives in Asheville NC, and I am in Texas). She changed the battery ... Read more >>
July 21, 2022 * 4 posts * 102 views
iheartmuhjeep said: I have been in the process of basically trying to replace every rusty part on my KK, which is like...every part. Anyway, the rear sway bar end-link upper bolts are seized. The ... Read more >>
July 20, 2022 * 3 posts * 114 views
2 jeeps said: I have seen similar threads on the board. I see, make sure its full of oil, is the oil switch above filter going out, is it the wiring? Some speak about oil pump going out. Question ... Read more >>
July 25, 2022 * 2 posts * 67 views
Greatpatch said: Hello- my 05 Sport has a clunking noise when I shift and let the clutch out normally. I have been babying it to not clunk. I have looked at it underneath twice. The first time ... Read more >>
July 21, 2022 * 6 posts * 181 views
EagleKJ said: OME/Bilstein JBA arms Just got my set of MOABs about a week ago. It's starting to come along. I'm originally from Cleveland. Wife's from Toledo. We moved here about 2 years ago. ... Read more >>
July 24, 2022 * 2 posts * 74 views
Burgermccartney said: I have a 2007 2.8L CRD which had a RAM fault code and was in limp mode. I've replaced the TCM which fixed the limp mode and no more DTCs. But it still has the ETC light flashing ... Read more >>
July 19, 2022 * 5 posts * 183 views
jamesbeat said: 2005 Liberty Sport, 180k miles. It is in stock configuration, no lift. When I turn the wheels to the left, I get a sort of creaking/knocking sound. It only happens when turning ... Read more >>
Continue reading...
