Highlighted posts from Tuesday, Aug. 23, 2022
JeepKJNewsletter
Click here to view on the web
Highlighted posts
August 17, 2022 * 37 posts * 910 views
tommudd said: Well there is one issue , can not use say OME springs and the adjustable shocks even set at 2nd level You will destroy your springs since you are preloading them , may ride well ... Read more >>
August 20, 2022 * 8 posts * 194 views
lfhoward said: A number of folks (like me) are running Jeepin By Al's adjust a strut lift kits. JBA stopped supporting or making these a few years ago. The question periodically comes up, what ... Read more >>
August 22, 2022 * 3 posts * 130 views
Karenymoreno said: HELLO FELLOW JEEP L❤VERS.. IM NEW HERE.BUT I NEED A LOT OF HELP ON MY BABY..I HAVE AN 03 JEEP LIMITED LIBERTY SPORT.. 5 SPEED MANUAL TRANSMISSION .. I HAVE REPLACED THE FRONT SWAY ... Read more >>
August 17, 2022 * 9 posts * 232 views
How To
Pt420 said: I have a 2007 Jeep liberty limited I replaced transmission tranfere case, front dif.,the throttle body, ignition coils, spark plugs,y pipe cats, all 4 O2 sensors, PVC valve, crank ... Read more >>
August 19, 2022 * 3 posts * 109 views
brehmel62 said: 2002 Jeep Liberty, 3.7L, 4WD I would check the low beam relay, but I can't find it. The junction block on the driver's side instrument panel only has one relay for the high beam ... Read more >>
August 20, 2022 * 4 posts * 134 views
bladerunner555 said: I had my AC compressor replaced a couple weeks a go. I can not add any refrigerant because the valve core was bent and would not make a connection allowing the refrigerant to enter. ... Read more >>
August 22, 2022 * 3 posts * 62 views
jeffreyropp said: Never really use 4WD in our old 2002, but tried to this weekend. Went into 4H without incident, but when I tried to engage 4L, the stick suddenly went loose and now the transmission ... Read more >>
August 16, 2022 * 3 posts * 161 views
nohitter64 said: Rear driver side window had the broken window clip issue Thursday. Fortunately I was prepared and had a new metal replacement clip. Swapped out the clip with my daughter being ... Read more >>
August 16, 2022 * 2 posts * 99 views
Rstep21 said: My A/C no longer blows cold and the A/C compressor itself gets so hot that you cannot touch it. Does this mean it's bad or could it be low on oil. Do I need to replace the compressor ... Read more >>
August 16, 2022 * 3 posts * 151 views
Synthetic-oils said: This was done over 2 years ago by Git it Garage. Just talk to Neil at Manley. We had a nice talk. Someone called yesterday. I filled him in on what is going on. The part number ... Read more >>
Continue reading...
