Highlighted posts from Saturday, Apr. 03, 2021
JeepKJNewsletter
Click here to view on the web
Highlighted posts
April 02, 2021 * 10 posts * 100 views
Kasey Hill said: Hi all. Let me start by saying I am not very mechanically inclined. I got a quote from a local shop to replace the front hubs on my 2004 kj, and it was over $800! I was able to ... Read more >>
April 03, 2021 * 29 posts * 521 views
tommudd said: LOL oh well I stand by my case and know several Mechanics ( oh wait Techs are what they are called now ) that never use a 1/4 inch , and you can use a 1/2 inch Done it hundreds ... Read more >>
April 03, 2021 * 21 posts * 517 views
Michael Wolfe said: I had a similar problem with my 2005 CRD. Due to a bad transmission sensor, I lost the overdrive, so the engine had to run at high RPM's at highway speed, causing it to overheat. Read more >>
April 02, 2021 * 6 posts * 120 views
Spr said: I bought my 2002 KJ Sport in Nov. 2019 and it's served me well. tommudd doesn't joke, these KJ's are little tanks. I needed a vehicle while I replaced the motor in my truck and ... Read more >>
April 03, 2021 * 11 posts * 222 views
flajeepdiver said: They work just no rapid clicking maybe I got a special kind? Read more >>
April 03, 2021 * 11 posts * 305 views
adamkrz said: Great write up and photos, Plastic solder and epoxy both a option -I was lucky to find 2 entire fuel pump assembly's in great shape -my next option was to maybe retrofit a newer ... Read more >>
April 03, 2021 * 4 posts * 42 views
Brendan said: My liberty overheated on the highway after getting it home and changing out crank/cam sensors after error codes and replacing the water pump/thermostat and PCM i think i have the ... Read more >>
April 03, 2021 * 3 posts * 134 views
tommudd said: Once upon a time there were ones available I have a set in the 04 Don't think they are made anymore. Is there a reason you want them ? Read more >>
Continue reading...
