Helping finding a lift kit
Riot
Richmond, VA
I've been searching the internet for months trying to find a simple 2-3inch lift for my 02 but so far I've had no luck only decent ones I see are way outta my budget or for 03 and up
So my question does anyone have any links to a decent lift that's kinda simple to put on that's not gonna break my bank?
Thanks in advance
Hedsic
Des Moines, Iowa
You will need to clarify what your budget is. If it's under $700 or so I'd suggest forgetting the lift and saving a bit longer.
Thanks in advance
Searching for months ?? Where have you been looking?
Simple lift kit? They are all the same pretty much, and very simple to install
Budget? If ( like mentioned above by Hedsic ) its under 750 or so, save up more cause it is not going to happen any cheaper .
Check Ironman or OME full spring setups ONLY way to go
Just say no to Rustys, Skyjacker, RRO, and any spacer lift
YEARS of experience on here , LOSTJEEPs and JEEPFORUM, and if you ask on any of those sites you'll find the same answers
Home page
All J Products - Aftermarket Jeep Products, Boulder Bars, Bumpers, Jeep Lift Kits, Skid Plates and MORE!
hectikart
Wilmington NC
Home page
Completely agree! Any kind of spacer lift is garbage and a waste of money. Definitely need to replace the coils, or else they'll be sagging again in 6 months. I have the ironman shocks and coils and I've been very happy with them. I've had the lift installed for almost 30,000 miles with no complaints.
wheeee32
Not the mountains.
Trust us when we say to save your money for a quality lift kit. Quality is better and the ride is better. Check out jeepinbyal´s website.
brokendad
Edmond, Oklahoma
Ironman
If I may, I would suggest the Ironman lift. I installed mine last December and it consist of the following: Ironman rear coils and Bilstein shocks with one extra insulator and two hockey pucks on each side. The front has the higher rate Ironman coils and bilstein shocks with two conduit lock nuts and a top plate from Jeepin-by-Al. I have just had the third front end alignment done since the installation and it drives better than it did when it was new. Most shops will re-align your vehicle for a year after the original alignment. I live in rural Oklahoma and have several miles of bad dirt roads to drive before I get to pavement. I personally could not be happier with the ride, but to each their own. By the way it has settled to 22.5 inches plus or minus all the way around. Now if life will just calm down for awhile I will get those JBA A-Arms!
:hunter:
brokendad
Edmond, Oklahoma
Tires & Wheels
The wheels are 16"x7" Cragar soft 8's with 4" backspacing and the tires are 245/70/16. I hope to up grade to Goodyear Dura-Tracs in 245/75/16 they will be a better fit in my opinion because they are not quite as wide of a tire. I will tell you that I originally had a Skyjacker lift and the ride and handling is horrible. Hope to see pictures of your Liberty when you get it done.
:hunter:
