We have a 2002 Sport and having a strange problem with the heater in this Jeep.
The Jeep blows hot air for about 2 seconds then goes to luke warm.
We replaced the water pump (because it was leaking), checked radiator for leaks and no leaks. Replaced T-Stat and flushed and replaced coolant. Replaced hoses.
Replaced the blower resistor because the fan speeds only worked on one speed.
So figure I had all my bases covered but the vehicle still blows no-so-warm air when heat set all the way. When the engine is under a load, it still does not blow hot air. The temp gauge shows normal (just under middle point of gauge)
Any other ideas??
Any other ideas??
