gas cap message
Discussion in 'KJ General Discussion' started by thegapgal, May 16, 2014.
  1. thegapgal
    thegapgal Full Access Member
    39
    Mar 10, 2012
    Ontario, CA
    I have a 2006 Jeep Liberty. I keep getting a GASCAP message displayed on my odometer panel and an audible ding. I ordered a new MOPAR gas cap and I continue to get the audible tone and message.
    What do I do now??
  2. Paul M
    Paul M Full Access Member
    232
    Jun 8, 2009
    Virginia Dale, Colorado
    Do like I did and disconnect then reconnect the battery, resets the computer for a few days which gets rid of the annoying ding...Hehe
    Actually, same deal here which means there is a leak in the EVAP system. Someone suggested I check the lines at the top of the fuel tanK for a leak (everything else in the engine compartment seems ok.)
  3. thegapgal
    39
    Mar 10, 2012
    Ontario, CA
    Thanks Paul. Great idea!!
    Did it solve the problem or do you have a leak in the EVAP system??
  4. Paul M
    232
    Jun 8, 2009
    Don't laugh but I've been running around with this thing intermittently going on and off for a few months. Annoying but no poor running conditions. Had planned to check the fuel tank lines this evening. Will let you know.
    Another thought I had (read it somewhere on the Forum) was (on the 2007 anyway) the smallish canister near the battery may be faulty. It has two vac lines running into it...might be worth swapping out.
  5. tjkj2002
    tjkj2002 Full Access Member
    10,614
    Dec 17, 2006
    That "gas cap" message is for a EVAP very small leak and is the hardest leak to find.This is were a smoke machine comes in very handy and a wiring diagram also since you will need to power and/or ground the purge solenoid and other evap system solenoids.
  6. Paul M
    232
    Jun 8, 2009
    Exactly why I haven't found it yet...more EVAP stuff routed around than you can shake a smoke machine. I did notice from the tank a small canister up under the body, possibly another obscure failed part. Finding this micro-leak may prove difficult. I'll look into the solenoids as a source...thanks for the tip.
  7. tjkj2002
    10,614
    Dec 17, 2006
    From all the KJ's I've diagnosed for small EVAP leaks has either been that little hose coming off the charcoal canister or the NLD pump.
  8. Paul M
    232
    Jun 8, 2009
    UPDATE: After fiddling around for a few months with a "Gascap" error I bit the bullet and bought a replacement Vapor Canister Purge Solenoid (CP648 - Standard Brand)...problem solved. Takes two minutes to replace. Maybe didn't need a new filler cap after all, but hey, after 120K miles nice to have a new one that clicks real nice.
  9. Paul M
    232
    Jun 8, 2009
    Another Update:
    Despite replacing the Gas Cap and Purge Solenoid - which for some reason worked for a while - the GASCAP error came back with a vengeance. Finally crawled under the back end, removed the EVAP canister (ok, who's idea was it to put this thing back there up above the axle??). Finally got the canister out...hoses seemed fine, cable looked fine. What I found after removing the white EVAP solenoid (or is it the NLD Pump??) - it twists off - was that one of the connector contacts had corroded away in the gap between the connector housing and the solenoid housing, hence a fault whenever the PCM did an EVAP test (no power to the solenoid). A Dremel and soldering iron made the repair to the contact, now no error (crossing my fingers tho). Pretty obscure failure, but beat buying a new canister for $90.
  10. colorado76
    colorado76 Full Access Member
    849
    May 16, 2011
    Rocky Mountain High
    When I had this same issue. I replaced the gas cap twice, that was not it, then I replaced the Purge Sensor/Purge Solenoid. That worked for a short time but finally in the end. I had to replace the Fuel Purge Pump that was my fix, for this issue.
  11. Paul M
    232
    Jun 8, 2009
    Same here...exactly what I did.
    BTW, where is the Purge Pump located? I'm assuming it's the white plastic assy attached to the EVAP canister that had the failed contact on mine, or is it another component elsewhere in the EVAP system spaghetti?
  12. colorado76
    849
    May 16, 2011
    Rocky Mountain High
    The fuel purge pump. True name is called ( the fuel vapor leak detection pump). It is located on the outer backside of the gas tank in the middle closest to the top across from the EVAP canister.
  13. Paul M
    232
    Jun 8, 2009
    Thanks...am thinking on the 2007 it's the module attached to the EVAP canister. So far no GASCAP error msg with the most recent repair.
