Fuel Pressure
Steve777
I am trying to diagnose a recurring P0093 code on my 06 CRD. It could be air getting into the fuel line, but I wanted to run the details of the error which were recorded by folks here to see if you think it might be due to fuel rail pressure, or something else. Here are the numbers:
Calc Load 59.2%
ECT 185F
MAP 32"Hg
RPM 1600
Speed 8mph
IAT 163F
MAF 5.07 #/min
Fuel Press 10768
Thoughts?
The rail pressure doesn't look too bad. They suffer massively from air leaks into the fuel system, there isn't a lift pump so the CP3 pulls all the way from the tank.
France 16 Olivier
FRANCE
I have more problem than you, gasoline leak and pressure. The CRD 2006 KJ drive good until you request more power. Then come the red oil warning and the CRD engine stop immediatly. My garage tried it on a 20 kms drive.
@KJowner can you help me to locate to buy the following parts on Autodoc Germany, especially the T one ( IMG_0306 ) wich is probably not available ? Gasoline sensor 45962073F, 5159964 (15) et regulator 68020556AA - 45962072G (13) found both on Autodoc Germany.
I need help on the IMG_0306 the T tube shape :)
I found this:
Hi, that is the fuel spillback or leak off tee, I'm not sure it's available any more new, I might have one on my parts Jeep, I'll have a look when I get home, if it's still there you can have it. I'm at work for 5 days now so it will be after that.
The other part is the rail pressure sensor.
When you say oil pressure light do you mean the fuel pressure or engine lubricant pressure?
France 16 Olivier
FRANCE
I think thats light red engine lubricant pressure but for sure i dont have motor oil leak, only gasoline. Thanks for looking.
That's a bit worrying, can you get a pressure gauge teed in to check the pressure.
France 16 Olivier
FRANCE
No I have ordered the 2 spares. My garage looks confident. Please just help me with the T. Maybe I can do 3D printer part if we have a model
France 16 Olivier
FRANCE
is it the part (20) : 05142649AA ?
