Fuel injector 3 leaking
Discussion in 'KJ General Discussion' started by Mobez27, Dec 1, 2019.
  1. Mobez27
    Mobez27 New Member
    Dec 1, 2019
    I have a 2005 liberty, 3.7ltr v6. I just replaced injector 4, but now fuel is leaking from top of injector 3. I tried reattaching fuel rail to injector but it didn't stop leak. Could it be o rings or a plugged/faulty injector? I read somewhere that injectors go out in pairs..is that a thing? Any info/advice is greatly appreciated!
  2. Aceofspades
    Aceofspades Full Access Member
    686
    60
    Jan 24, 2017
    Buffalo
    Always replace the o rings and make sure you lube them up. Going in dry can ruin the sealing ability of the o ring
  3. Mobez27
    Mobez27 New Member
    Dec 1, 2019
    Should I replace all o-rings on all injectors (minus new injector) or can I get away with just replacing top rings?
  4. Aceofspades
    686
    60
    Jan 24, 2017
    Buffalo
    Well when you take the rail off you’re going to be messing with all 3 injectors. The o rings are cheap enough to replace and not have to waste time to do this again or worse have a leak go unnoticed and well yea.
  5. Shane Giggie
    Shane Giggie Full Access Member
    83
    Nov 26, 2019
    Should have replaced them all when you did the one.
