Front Driveshaft Removal
Discussion in 'KJ General Discussion' started by bmrrwolfe, Apr 1, 2010.
  1. bmrrwolfe
    bmrrwolfe Full Access Member
    1,757
    Jul 23, 2009
    North Olmsted, OH
    So I found a torn rear boot of my driveshaft and I have a sound of something like a bad bearing which may be or not be the driveshaft but it is alright to remove the front driveshaft and drive around a for a few weeks correct?
    I emailed ericautoparts but he is out of stock of the length I need.
    Also its just the 8mm bolts holding it in correct? No special tricks to getting it out?
    I've seen a few posts where people were talking about a u-joint conversion but it causes vibrations. I searched but couldn't find much about it are there any posts about it on here?
    Thanks!
  2. Warren.fischbeck
    Warren.fischbeck Full Access Member
    1,091
    Aug 26, 2009
    Alton, IL
    You'll be fine pulling the driveshaft for a while, just don't try to engage 4x4 without the front driveshaft. 8mm bolts on both ends; take the end closest to the transfer case out first, slide the shaft over the transfer case and twords the back of the jeep to disengage the diff end of the driveshaft then it should just come out.
  3. family KJ
    family KJ JPOTM WINNER
    393
    Feb 21, 2010
    Tampa, Florida
    Changing the front drive shaft was the first repair I personally did on my jeep. Very Easy (and I am not a car mechanic at all) nothing to move out of the way. Just remove those small bolts on each side of the shaft and compress together as Warren said. A new shaft cost me $200, I didn't shop around too much, but I would buy new, not off of a wreck.
  4. Idaho08KK
    Idaho08KK Full Access Member
    292
    Jun 29, 2009
    Idaho
    The only tip I would offer is once you get the bolts out of both the front and rear, pull the rear part of the driveline forward, push it up over the yoke on the t-case, then pull the front out.
    I have done several of these, and if you try to pull the front of the driveline out first, it is pretty hard to get the driveline out of the yoke on the front diff.
    I apologize if it is hard to understand what I'm getting at. It would be easier to show you than to sit here and explain it.:D
  5. bmrrwolfe
    1,757
    Jul 23, 2009
    North Olmsted, OH
    Haha i understand what your saying.
    Thanks for the help all!
  6. RenegadeMarine
    RenegadeMarine New Member
    Jan 28, 2010
    Fraser, MI
    Where the heck did you find a new front drive shaft for $200? The stealership here wants $550!
  7. family KJ
    393
    Feb 21, 2010
    Tampa, Florida
    I will have to get with my Dad, he is retired and loves searching the internet for deals. I know it was a place in NJ that buys overstocked items from dealerships, full warranties..I will post it when I find out.
  8. bmrrwolfe
    1,757
    Jul 23, 2009
    North Olmsted, OH
    Could you please let me know if you find out where he got that deal!! :)
  9. bmrrwolfe
    1,757
    Jul 23, 2009
    North Olmsted, OH
    Yeah i talked to him, hes out of stock of the one i need...
    Hopefully he will get one in soon though.
  10. damon1122
    damon1122 New Member
    May 26, 2010
  11. jnaut
    jnaut Full Access Member
    2,237
    Apr 17, 2008
    Seattle
    Cool. Except I don't get something from their website:
    NOTE: MIGHT REQUIRE SLIGHT MODIFICATION TO YOUR SHIFTER BRACKET TO INSTALL
    Well, does it or doesn't it? If they've made these for Jeep liberty's, wouldn't they know? Then this:
    When you are ready to order we need to have a flange to flange measurement.
    Again, if they've made these for Liberty's, wouldn't they already know?
  12. JeepKid37
    JeepKid37 Full Access Member
    25
    Feb 20, 2018
    Jerseyville, Il
    Ive found mine for about 150.
  13. Aceofspades
    Aceofspades Full Access Member
    652
    49
    Jan 24, 2017
    Buffalo
    Word of advice $130 front shaft lasted like 3-4 months before it started shaking my jeep to death at speeds over 50 mph ...
    I found American CV online and got a heavy duty one for $200 - they also sell on eBay too and it’s a beast. No more vibes
  14. jeeptorino68
    jeeptorino68 Full Access Member
    811
    21
    Nov 28, 2011
    Oregon
    Guys....I doubt the OP is still looking for a front driveshaft 8 years later....
  15. smittyfromPA
    smittyfromPA Full Access Member
    200
    Nov 7, 2013
    PA
  16. Aceofspades
    652
    49
    Jan 24, 2017
    Buffalo
    Yeah but it helps other people who may refer to this thread later on
  17. Myke
    Myke Full Access Member
    562
    Nov 13, 2016
    USA
    Call up Adam's for a custom built shaft if you want a HD reliable shaft. This will be over kill for most people.
  18. tjkj2002
    tjkj2002 Full Access Member
    10,614
    Dec 17, 2006
    As long as you don't mind vibrations.
    The front diff and t-case are not lined up correctly for any non-CV(meaning actual CV joints,not referring to Double Cardon CV's) so you will get vibs no matter what unless you use the OEM style CV joint driveshaft.
  19. RenKJ
    RenKJ Full Access Member
    305
    Feb 19, 2015
    Canada
    They claim to have it balanced, and i kinda like the idea of what they built if i can get it with grease nipple on the joints, thoughts?
    Sent from my A0001 using Tapatalk
  20. smittyfromPA
    200
    Nov 7, 2013
    PA
    Thanks. I'm getting pulsing vibrations over 55 mph now so I don't want it worse. I'm going to go with the rebuild kit and see how that turns out.
