I have a 2006 Liberty. 80K. 6 Speed manual. All Stock, not mods. The following have been replaced recently: Rear: Trailing Arms, Upper Diff Mount. Front: Upper A-arms, Lower Ball Joints, Tie Rods, Wheel Hubs. Also: Replaced rear drive-shaft (due to looking like OEM one lost a balancing weight). Now that all that is new/replaced, I'm still getting a growling noise with slight vibration coming through the steering wheel, especially during in gear-acceleration. I checked the play on the front driveshaft by itself, none to be found. But if I try to rotate the front driveshaft (car on ramps, in gear, 2WD mode, not running) I notice what I think is too much play in the inner CV joints on the front axle. If I hold the inner CV joint housing and then try to turn the front driveshaft I find no play in the diff. But from the inner CV housing to the front axles I find what seems to be too much play in the inner CV, on both left and right axles. Outer CV joints seem to have no play at all. All the axles boots are in good condition with no leakage.
Question: Are the inner CV joints known to wear on these Libertys? Or could be just a case of age and mileage? What are symptoms of the gearbox input shaft failure that I have read about?
Thanks, Ed.
Thanks, Ed.
