Hello,
I have a 2003 Jeep Liberty without ABS. I had my local Jeep dealership install new brake pads and they said that turning the rotors was all that was necessary and that replacing the rotors wasn't needed.
I was worn down to only 5% of brake pad left on both pads before I took it to the dealership and the braking power of the Jeep was still sufficient, and the pedal was firm.
After I picked up the Jeep from the dealer, I noticed a significant difference in the braking power. It was much WORSE. The pedal turned into a sponge and the front wheels would not lock up no matter how hard I pressed down on the pedal. Even if I pushed it to the floor. Even going 20 mph, the vehicle hesitates to stop.
I noticed this significantly when I drove it off the dealer's lot and almost crashed into a car at a traffic light.
I brought it back to the Jeep dealership the following morning and pointed these specific problems out and mentioned:
1) Did the mechanic turn the rotors and thin out beyond the minimum specification?
2) Did the mechanic push air into the braking system when he installed the new brakes after connecting the piston to the caliper?
3) Did you use the correct brake pads (NON ABS)?
Result was that my vehicle sat in the garage untouched for 2 hours. I had someone take me to a nearby restaurant to get lunch and then when I got back the Jeep was sitting out in the lot.
I asked what they did. I was told that the braking system was completely bled out and that it should be fine.
I drove the vehicle with one of the service personnel around the lot and nearby street. I still mentioned that the pedal was extremely soft and spongy. He downplayed it and acted as if it was "normal."
I eventually left after telling them I was not satisfied and speaking with the service manager who didn't do anything to rectify the situation.
So I called the Corporate Chrysler number and explained the scenario above and then got a call back the same day stating that the shop "repaired" the vehicle after the "first time" (when the new brakes were installed).
I called Corporate Chrysler back and explained in further detail as to specifically what happened literally verbatim with specific names and mechanics, etc.
Then the same individual called me back from Chrysler Corporate and stated that my options at this point were to take it to another Chrysler dealership and have it inspected and then follow up with Chrysler Corporate with my Case number.
I informed him that I would be taking my Jeep to an Independent Repair Facility that specializes with Jeeps and have the following things checked:
1) Were the brakes in fact actually completely bled as the dealership stated?
2) Is there a difference as to what kind of brake pads should go on a NON ABS Jeep?
3) The thickness of the rotors and if they were turned when they should not have been or if the rotors are now damaged because of the Chrysler dealership.
(Should not be affected by a brake pad replacement, but will have them inspected anyway
4) Master Cylinder
5) Proportioning Valve Diaphragm
6) Brake Booster
I explained to the Service Manager, on the phone, that if the Independent Repair Facility finds any fault in the workmanship of the Jeep's braking system that I will demand a full refund or I will file a chargeback with the credit card company under the clause that the services were not rendered as described and I will provide documentation from the Independent Repair Facility and explain that I contacted the dealership several times and Corporate and received no remedies.
I then added that I would take his dealership to small claims court in this county and file an official Complaint for the total amount of the repair work if any attempt was made to collect on the chargeback and that I would utilize my existing legal counsel with whom I already have an established attorney-client relationship with on a separate legal matter.
Any suggestions, fellow Jeepers?
Am I being pushed around? Shouldn't the braking system be noticeable BETTER if anything after getting NEW brakes.
Why would the OLD braking system work better than the NEW brake installation?
Obviously something happened at the dealership and they don't care about solving it for me.
I will keep this thread updated with the news as I get it.
opcorn:
4) Master Cylinder
6) Brake Booster
opcorn:
