Hi all !! pleasure to have made it here finally after owning a Liberty (Extreme Sport Cherokee) many years now. First acquired my Jeep 15 years ago in the UK and since relocated to Spain where we are both much happier. Just came across this forum as I ran into a strange issue following a turbo replacement recently. Everything running seemly well for a few miles but then the speedometer suddenly stopped working followed shortly by the ABS and brake indicator lights staying on. I suspect the VSS sensor, Earth or wiring from the vss sensor to be at fault but weirdly unrelated to the Turbo replacement. I guess its possible a wire got trapped somewhere but I will check resistance on the vss first I think. Any tips most welcome ! Being the optimistic type, at least I discovered this new group of pals thanks to this issue so not all lost after all
Happy troubleshooting folks.
Additional info regarding fault, RPM working fine and automatic gears also as I have done 1000kms past couple weeks with live issue, very good fuel economy as I cannot accelerate ! Also did the reset test and speedo needle works fine.
I will check for resistance on vss sensor and it would be great to test for continuity between connector and PCM but which of connectors and which pins? pictures would be great ! Thank you
