For lifted kjs - custom driveline required?
mercdudecbr600
Hi all. For the last 5 years or so I’ve had a lifted kj. Nothing crazy, just the ome lift with no spacers.
After regearing to 4.10, I’ve got vibrations through floorboard at 70mph+. Had both driveshafts rebuilt or replaced but I continue to get the same at high speed 70+. I Have gone through a litany of new parts, wheel bearings, intermediate shaft, cv axles, oem mounts which did help significantly but it’s still there.
Having pestered the driveline shop enough they finally started asking hard questions like, what is your rear pinion angle relative to your tc output shaft, and your u joint operating angle?
Long and short of it, I’ve got an excessive u joint operating angle at something like 5-6deg. Supposed to be 1-3deg.
And since I’m not the most extreme of lifted kjs figure others here MUST have figured out a solution.
Mind you, this only came about because I’m now spinning 24-2500 rpm at 70mph. I’m guessing I always had this issue after lifting and didn’t realize it because with 3.73 and 31” tires, I never got to the propshaft speed necessary to vibrate.
Help and/or thoughts are welcome!
24turbo
Alberta Canada
Im not talking from direct KJ experience here so take it for what it is worth.
There is adjustable hardware for the rear differential and specifically the upper control arm. I believe it is from a YJ and there is a vendor that makes a bracket to adapt to a KJ differential upper mount (WWdiesel?) I would start there and change your pinion angle to something a bit closer to 3 degrees. You may also need to change the lower control arms to something a bit more rigid, as the factory ones have soft rubber bushings which probably are not helping. You could also go the route of just doing adjustable lower control arms and adjust pinion angle that way.
Also worth noting is you want the driveshaft angles at your 2 locations (transfer case and differential) at as close to the same angle as possible, whatever that happens to be. U-joints operating at an angle actually change the rotational speed of the driveshaft (Im sure there is a u-tube video explaining this) through its rotation and if the 2 are matched they cancel themselves out.
mercdudecbr600
Appreciate the feedback but I already have adjustable rear lower control arms, so changing the pinion angle is not the issue. Right now my tc and pinion measure at 5.7 to 5.8deg, so their parallelism is fine. The issue is that the operating u joint angle exceeds 3deg - I’m sitting at double that, around 6deg.
Even with fresh oem mounts, a balanced driveshaft with the oem harmonic balancer and the harmonic weight at the rear diff, im still getting vibs at final drive above 24-2500 rpm.
To note, I have the 45rfe trans which runs higher rpm’s than the later trans (so this magnifies the issue) but I believe the operating angles are an issue for every lifted kj.
That said, I’m sure someone has had this before and ended up with a double cardan (cv) driveshaft.
mercdudecbr600
You can’t just adjust the pinion to reduce the u joint angles because it will throw off the parallelism and make things worse.
Theoretically you could drop the trans cross member and then tilt the pinion up to match the tc angle and see if that would get you under 3 degrees but using my math skills the best I could get reasonably is 4deg operating angle.
24turbo
Alberta Canada
Thanks for the lesson on driveshaft angles!
I guess you didnt bother to read my entire post:
"Also worth noting is you want the driveshaft angles at your 2 locations (transfer case and differential) at as close to the same angle as possible, whatever that happens to be. U-joints operating at an angle actually change the rotational speed of the driveshaft (Im sure there is a u-tube video explaining this) through its rotation and if the 2 are matched they cancel themselves out."
In case you didnt get what I was saying, its the same as "parallelism" (fancy term!). When you raise the rear suspension it changes pinion angle and you need to adjust it so its the same at the transfer case (which if not done will make it worse). All I was trying to do was offer some help. Maybe you should remove this from your first post:
"Help and/or thoughts are welcome!"
Since you are so convinced your driveshaft angle is too much (which it is) and cant be changed- easy button: BUY A NEW DRIVESHAFT
mercdudecbr600
Sorry about that, not intended to be critical. Yes I understood what you meant about pinion angles.
The thing is: with coil spring 4-link rear suspensions found in jeep, raising or lowering the rear ride height doesn’t affect pinion angles. The lengthening or shortening or suspension does though. raising and lowering does affect u joint operational angles because the driveshaft is at a higher angle to connect the tc to rear diff.
My pinion and transfer case angles measure as matched and cancel out. But, the high u joint operating angles create (basically) binding and oscillation at high speed, aka vibration. And that situation is not unique to my rig, same for every vehicle that uses a single u joint driveshaft.
What is unique to my rig is that I have the older driveshaft with the harmonic balancer on it which adds considerable rotational mass and that (I’m guessing) amplifies the effect. U joints are new and so is tube. So really no difference if I get another driveshaft or not.
2nd03liberty
Mercdudecbr600, Did you ever find a fix for your jeep?
I think we have the same setup, and the same problem.
I have an 03 45rfe, moab wheels 31s 3.73s that has been ome lifted for a few years now. Had a pretty bad vibration at 80mph and up, but never drive at that speed so it was no big deal.
This spring (march 2026) I swapped in a set of 4:10 axles from a junkyard 4cyl. The fluid in them was like brand new. They were both super clean inside. Also did the creative steel front diff bushings. Now over 64mph I get a pretty bad vibration, that sounds like it is coming from the front, that led me to do the front right side diff bushing/bearing conversion new intermediate shaft and CV axle, didn't solve my problem...
I removed my front driveshaft, thinking it could be that, nope wasn't it either. drove with it not installed for 500 miles, still had the vibration.
I did U joints when I did the axle swap, and used cheep O'Reilly's joints, so I am considering doing them again.
mercdudecbr600
Mostly yes. For me, I ended up replacing front driveshaft a few times. Nearly perfect until 75mph and then a slight vib hits and gets worse.
In your case, With the front driveshaft out, vibs are probably coming from the rear. Check your rear differential angles, likely they are off and/or the driveline needs to be balanced. This is where the adjustable rear helps a lot. I also found that clocking the rear driveline helped. First try rotating your driveline 180deg at the rear diff. If that doesn’t help, go 90deg at the trans then 45 and so on.
See if that helps
2nd03liberty
How would you recommend checking the angles between the rear drive shaft and the TC flange/pinion flange. My jeep has the flanges that you just bolt the ujoint right on to the axle flange with the small saddles over two of the ujoint caps. Then at the TC end the only way to get the rear shaft out is to take apart the ujoint. I have seen the other type of flat- flange to flat- flange that just bolts together, but mine is not like that.
Just crawling under my jeep and looking. It looks like your pic above (the "terrible" one) where the TC has some angle, but the axle to driveshaft has almost no angle difference.
All just eye measurements though.
I did both the lower control arm bushings, and did a whole new upper control arm this spring.
mercdudecbr600
My rear driveshaft had the same setup - the u joint splits apart from the rear diff and has 2 small caps and 8mm bolts that hold it all together. The other style is for later kjs and definitely kks.
Most reliable angle measurement is vertically along the machined spreader flanges adjacent to the rear diff cover. Then I measured that against a machined flat spot on the tc, also vertically. You’re only talking a degree or so difference but it can affect vibes. Again try that 180deg swap thing first.
And I found the iron rock adjustable diff incredibly useful for getting it nailed down.
i also ended up taking the front balancer off the rear driveshaft and lengthening the tube a bit (like a 3/4”). And eventually I tried a double cardan style driveshaft and that nearly exploded - apparently not enough angle to get the u joints to rotate.
burntkat
Look into the Iron Rock rear upper control arm assembly - direct replacement for the stock arm and gives you adjustability to correct driveline angles.
This is the answer.
NOTHING from a YJ is going to fix the issue.
burntkat
Funny, this is exactly how you fix the problem. The upper and lower arms were never parallel, so concerns about affecting it get flushed to /dev/null
mercdudecbr600
That’s not the parallelism we’re talking about. It’s the angles at tc vs rear diff so the u joint vibrations cancel out. If you change the angle at the tc, then it wont match the rear diff angle. And that’s how you get (more) harmonics.
Though dropping the trans down will reduce the operating angles of the u joints and that does help harmonics. But it’s not really feasible to get the trans down far enough to make much of a difference. A 0.5” drop only reduces the operating angle by 0.3deg or so.
The iron rock rear upper control arm is a direct replacement, so it may have been derived from another jeep but it fits the kj just fine and does a great job.
24turbo
Alberta Canada
There are lots of videos on YouTube explaining how to determine all the angles. All you really need is a digital level.
I made a tool for checking angles years ago using a choke angle gauge. That was back when Rochester carburetors were still common. I checked around and they are a pretty rare tool now.
burntkat
This is the way. It doesn't have to be a certified instrument. One off Amazon or Harbor Freight for 20 bucks will be fine. Hell, most cellphones would be fine.
Examples :
Or
mercdudecbr600
The c8.25” is relatively hard to get a good angle measurement -
I struggled with this myself. The only good flat part is the machined bits next to the rear diff cover on the backside of the axle.
burntkat
Remove driveshaft. Use the pinion flange as the reference. This is pretty standard. Super simple.
