Fog Light Options (2005-2007)
octafish
I just upgraded my headlights on my Liberty ‘06 to custom projectors with HID (recommended, by C4 Lifestyle).
Now I need to replace my old yellowish fog lights. I’m interested in some aftermarket LED or projector options and was wondering what ya’ll might recommend.
I've found that using a 4300k hid bulb puts out more light and gives better visibility than a higher temp. Plus my regular fogs almost match them perfectly. Not sure why C4 doesnt give an option to get a better temp hid.
The retrofit source has good HID's. I know this isnt the answer you're wanting but youre not going to be able to match the factory fogs up with the blue lights.
octafish
I actually just scored some used PIAA fog lights (reflector, LED) on eBay! They have almost identical dimensions to the stock ones on my 2006 Libby (3.5" diameter). PIC ATTACHED.
octafish
While I would have preferred projectors (maybe even with halos) these are PIAA and should give a way better light output than the aftermarket options I've run into on the internet.
Much better than projectors with or without halos
Hella has some great ones also , I have 2 sets of them laying around, always did great
Took them off when I installed the VISION X ones
Some of the PIAAs are too bright to run all the time though , will blind oncoming traffic bad so be careful
