Fluid leaks?
Dane
I’ve noticed I have a coolant leak. Topped it off last month and already had to top it off again. In my search for the coolant leak I noticed some other areas that are leaking. Can you help me identify potential issues?
I noticed what looks like maybe oil coming from front drive shaft.
Then I also noticed that two bolts for the transmission right above the oil plug were leaking too.
Thoughts? Looks like this might be a bigger job than an amateur should take on.
