Aloicious
Ok, so I know ECM failures are uncommon, but Im starting to suspect it, so Im just looking for any thoughts from others before i go looking for a reman ecm.
Basically I have a consistent P0155- bank 2 sensor 1 o2 heater circuit malfunction. Always.
Ive replaced the sensor twice, no change, swapped sensors bank to bank, no change (code does not follow sensor, always bank 2 sensor 1), i found one wire that had been pinched between the bell housing when I did the clutch, so i clipped out the damaged section and resoldered/sealed it up, no change. I went ahead and unwrapped the harness back a ways and clipped out the whole B2S1 connector and soldered/sealed in a whole new pigtail, no change.
Here's the weird part, through all this I can watch live data and the B2S1 and voltage and trims look normal. But whenever the P0155 freeze frame data is reviewed, there is ALWAYS a very strange erroneous value, sometimes its a STFT reading of -38, sometimes its an RPM value of 16,000+. These are never seen in live data, only the code freeze frame data, and obviously outside the capability of the sensor/engine, which is why I'm starting to suspect the ECM.
I know some various jeep models had problems with ecm pins failing internally.
Any thoughts would be appreciated, im kind of at a loss at this point. I don't know what else besides the ECM could be causing this.
This is a 05 sport, 3.7L, 6 speed manual, 4wd, mostly stock libby. 265k miles
