Doing some maintenance today :D
Discussion in 'KJ General Discussion' started by dude1116, Dec 21, 2011.
  1. dude1116
    dude1116 Full Access Member
    3,369
    May 31, 2011
    Pompton Plains, NJ
    Hey guys! Couple of questions i think you guys might be able to help with. Anyone know how to get the fog light bulb out of the Jeep? Also, what does a bad water pump sound like? I think I might have one.
    Thanks per usual everyone :D
  2. HoosierJeeper
    HoosierJeeper Gold Supporter/Admin Staff Member Administrator
    20,736
    111
    What year KJ? If an 05+, just take the grill off, and above each fog light there is a screw to take the lens off. :)
  3. dude1116
    3,369
    May 31, 2011
    Pompton Plains, NJ
    Gawww forgot to mention that. '04. I think I figured it out, but they don't twist off. I think they're stuck. :\ All i need is to get the bulbs. I don't need to take the lens off or anything crazy like that.
  4. dentwizz
    dentwizz Full Access Member
    86
    Jul 7, 2009
    Strasburg, PA
    A bad Water pump will usually sound like a "wooo" when the engine is running normal. The easiest way to do the audio test is to find it with the engine off, then monitor that location to differentiate it from the ambient engine noise. The other telltale will be a noticeable sweat on the seal of the shaft. If it is beyond a sweat, you should have the new pump in stock...
  5. LibertyTC
    LibertyTC Well-Known Member Staff Member Moderator
    7,205
    432
    To access fog light, is in fender up front with a little plastic door.
    It does twist out, counter clockwise I believe. Use a bit of WD-40/hairdryer heat to twist em free after removing the wiring clip. Dirt gets onto rubber seal and sticky city.
    Note you can greatly improve the wattage of the fog lights by using 9005 ST bulbs.
    I used silverstars and a simple mod to one of the tabs is needed to install those 65 watt bulbs.
    What a difference with the 9005ST's If you get them and have question about tab mod PM me.
  6. dude1116
    3,369
    May 31, 2011
    Pompton Plains, NJ
    Ah really? I already grabbed the stock bulbs. But definitely something to think about. But you're right though! I can't twist the goddamn thing out of the socket!!!!! I've used all of the above. Except heat. I should use heat I suppose...
  7. LibertyTC
    7,205
    432
    The stock fog bulbs are dim take them back and get the 9005ST.(F-150 high beam)
    Do the mod.
    I run PIAA 9007 Extreme White in the main headlights which also are a huge improvement over stock.
    [​IMG]
  8. dude1116
    3,369
    May 31, 2011
    Pompton Plains, NJ
    What's the mod with the wire clips? Might as well post it here in case other Jeepers wanna do it! :p
  9. LibertyTC
    7,205
    432
    Nothing to do on wire/clips.
    In the PM, it is just compare the stock bulb to the new 9005ST and it becomes obvious which part of the plastic tab needs to be trimmed on the new 65watt bulb, to fit our housing.
    The tab mod came from Jeep projects link that has since gone away and had the photos to explain it better.
    I have searched my computer and only found one screen capture that I took from a year ago! Does not show it the best but best I can do to explain it without having to pull one of my fog lights to do a real side by side.
    [​IMG]
    One tab needs to be trimmed on 9005ST. I have marked the tab with X that I thought was the one that needed trimming. Just compare them side by side and you will see one is a bit too long.
    Cut the tab to match the stock bulb. Done. Enjoy your bright new SilverStar fog lights!
  10. TwoBobsKJ
    TwoBobsKJ Full Access Member
    2,637
    Jan 28, 2011
    Northern Ohio
    Tim, your OCD habits pay off! :party52: This is awesome - I was just complaining last night while driving in mist/rain/snow flurries that the OEM fogs don't cut thru like I'd like. You've posted this before but with the pic you found this shows it's a no-brainer. Will be doing this mod next week...
    Wait...Does this qualify as a mod since I only have to trim the tab on the 9005? Feel like I'm cheating my mod list :gr_grin:
    Merry Christmas!
  11. TwoBobsKJ
    2,637
    Jan 28, 2011
    Northern Ohio
    Rebate!
    FYI, just did some online checking on the 9005-ST's and for those of you stateside AutoZone has a $10 rebate on the Silverstars - $40 minus the rebate, you get the pair for $30.
    Pretty good for a significantly improved bulb.
  12. LibertyTC
    7,205
    432
    Ya no problem but I just had to edit the photo as I think I had the bulbs marked wrong.
    So once again I hope I got this right. It is really too bad that their site from Jeep projects is gone. SO if anyone else has got a screen capture of a 3 pics that really did it justice, feel free to post them. I know It may be confusing ..one day when it is warmer I actually should take my modded fog bulb out and show exactly which damn tab needs trimming with a real side by side photo. I think by comparing them though you should be able to make it happen.
    ya Merry Christmas to all...me still hung over from last night's wine contest!
  13. dude1116
    3,369
    May 31, 2011
    Pompton Plains, NJ
    Oh I see! That should be fairly easy!! What did you use to trim it down?
    I'm totally gonna be all over these bulbs next week!!!
  14. tjkj2002
    tjkj2002 Full Access Member
    10,612
    Dec 17, 2006
    I just used a sharp knife,takes about 10 seconds per bulb.Remember not to touch the bulb glass.
    Just a heads up also those 9005's are a bit to much for the stock foglight wiring.Use the 9005's at your own risk.Yes I have run them since '02 but I'm alos on my 10th or 11th bulb connector as they get to hot and start melting.During the summer it's not a major issue as I do not to alot of driving in the dark during the summer.The winter is another story since it get's dark at 5pm so I check the connector ends every 1-2 weeks and replace as needed.I carry a few spares at all times,there cheap at most autoparts stores.
  15. dude1116
    3,369
    May 31, 2011
    Pompton Plains, NJ
    Hmmm...not sure I would want to constantly be spending the time re-wiring that. Has anyone else had this problem?
  16. j-rod
    j-rod Full Access Member
    292
    Apr 28, 2010
    Farmington, WV
    you all are discussing the 02-04.
    what about 05-07 fogs?
  17. LibertyTC
    7,205
    432
    The 9005 mod applies to KJ's which stock bulb is 9145 only.
    I guess when they moved the new fogs up beside the grille in 05 they changed the bulb to?
  18. j-rod
    292
    Apr 28, 2010
    Farmington, WV
    there are two bulb options in 05. My wifes KJ takes the 9145 so this mod should probably work then too?
    The other option bulb is H3.
    How many of you all have had to deal with replacing the pig tail connector from melting?
  19. dude1116
    3,369
    May 31, 2011
    Pompton Plains, NJ
    I'm PRETTY damn sure the fog in the grille is a completely different assembly.
  20. j-rod
    292
    Apr 28, 2010
    Farmington, WV
    hmmmmmm. it takes the same 9145 bulb as the 02-04 so it should have the same connector and such right?
