Does anyone know the book time to replace a E-brake
GitEmSteveDave
Howell
The dealer sent my Jeep to have the ****** looked at from 5/7-5/11 and have had it back since Saturday 5/12. The only job needing to be done is replacing the rear emergency/parking brake. I just spoke to the manager and he said it SHOULD be done tomorrow, 5/17, but I he'll get back to me after 12pm, which means ANOTHER day of a rental car, at least.
So does anyone know what the average book time to replace the rear drum ebrake is? I watched some youTube videos and people seem to have gotten in done in under an hour. Also wondering if any of you have done it yourself and how long it took so I can start raising hell as to why a fully equipped dealership can't get it done in 4 days.
Thanks-
Damotee
Cape York, Australia
It took me about 2 hours to do mine. It was a real PIA but shouldn't take longer than 2 hours or so, especially in a shop that has access to better tools than I have..
edit; this is assuming theyre only replacing the brake drum parts, not the whole cable setup as well.
JasonJ
Michigan
Thanks-
While I agree, it seems they've had the vehicle for a while, don't forget that yours is not the only vehicle in the shop, and you aren't aware of their staffing levels or other things that affect how quickly a vehicle can get in and out of the shop.
In some cases, they may have technicians that are specialized or the only ones trained in certain repairs or procedures, and that may tie those guys up for a while. Plus, if they had to sublet the transmission work, how busy is that other shop? Is it a smaller but more experienced shop with only 1-3 techs? That means the Jeep is going to sit there for a day or two before they can get a free lift to check it out.
It's not always as simple as drop it off, technician brings it in and works on only your vehicle and only until it's done.. dude needs to work on as many vehicles as he can in a day to make a living.. which means a specific vehicle may be brought in or pulled out of the shop a half dozen times over two or three days.
Phil + Neela
Vancouver, WA
On Oahu, it took three weeks to get parts and a full week to install. I had to get the cables replaced to pass inspection.
Thanks-
Depends.
The whole parking brake assembly requires the axles to be pulled and if I remember right it calls for about 3 hours,double that if replacing the cables also.
And JasonJ is correct your vehicle is not the only 1 being worked on.Some days I'm working on 5 or more vehicles at the same time.Then you got to think if they need to order the parts they have to wait just like you.
towpro
SE pa
My backer plates were still good so with standard brake tools I was like 1.5-2 hours working off floor with Jack stands.
I think they make aftermarket backer plates that don't require pulling axle? (Dorman?)
GitEmSteveDave
Howell
I feel like I never got across that the dealership had been jerking me around since a little after I pushed the cash across the cashiers counter. They have ~15 technicians and told me they ordered the ebrake parts from Jeep ~2 weeks before I brought it in because they had been ignoring me for a month.
I was just frustrated because they kept promising me they would call me at noon the next day and every day was me calling/emailing at 2-3pm and told the same thing for the next day and I was paying for the renal car.
u2slow
BC
They're probably waiting for parts. If the trans is done, I'd tell the dealer to stuff it and get your Jeep back. Do the parking brake yourself... its a DIY driveway/hand-tools job.
