iamweasel
Riiight, I've been planning this build for ages now and I finally got all the bits together that I need. (I won't mention that someone who will remain nameless, threw away the first batch of LEDs I ordered)
We've all seen those ridiculously over-priced LED light bars:
http://www.rigidindustries.com/product-p/eseries30.htm
Well, here's a guide on how to build your own LED spots. I'm building two spots - not a light bar, but the parts I'm using would perfectly suit a rectangular lightbar.
This setup will (in theory) generate the same amount of lumens as the 30" $1000 lightbar above (12000lm). I know I know, lumen values aren't a direct measure "brightness". Luiminous intensity - "brightness" - is a factor of how those lumens are focused
....Aaaaanyway, the optics I've chosen give similar beam angles to the Rigid Industries (R.I. for future reference) light bar , so the 'brightness' should be comparable.
Parts:
I'm gonna use fibre glass to recreate the OEM shape.
If you wanted a R.I. style lightbar, you can find lots of aluminium extrusions at your local hardware store that would work.
The cost? about $100.
The LEDs:
The Heatsinks:
The optics laid out on the heatsink:
As you can see above, the optics definitely lend themselves to the RI style lightbar. I'm pretty sure they use the same optics.
The optics come in these holders:
Some of my calculations to determine the required beam angles:
The sketch on the left is a top-down view, showing the beam width at certain distances: 50m, 100m and 200m. I aimed for a 20m-wide beam at each of those distances. I'll have to wait for a trial run to see if my speculations on these beams angles are correct.
The optics are cheap though - about $1 a piece - so changing the beam angles is no biggie - cheap and easy.
Circuit diagram of the power supply:
I'll be tweaking this to run 3 LEDs in series, not 2 as show here. LEDs need a constant current, so this bit is crucial. I looked all over the net for a suitable DC-DC transformer, but ended up with the plan to make one from a circuit design I found online.
Step 1: Prepare the heatsinks for the LEDS
The heatsinks I ordered had a ridge on them which I had to grind down.
The smoother/flatter the better the heat transfer will be. Each of these LEDs is 10W, so good heat dissipation is necessary.
Decide on a layout and drill holes for the LEDS:
Step 2: prepare the optics
I wasn't able to get hold of Ledil optics specifically for the Cree XML LEDs, so I ordered ones for a similar Cree LED. A bit of Dremel-work was necessary...
Typically the LEDs would be screwed directly to the heatsink, but this can cause shorting issues between the LED, screws and heatsink.
What I decided to do, is screw through the optic holders and LED board, into the heatsink. like this:
That's as far as I got this weekend...
Next steps:
Shout if you have any questions
Parts:
- 12 x CREE XML T6 LEDs
- 12 x Ledil optics (each spot: 2x 8° spot, 2x 14°x46° oval, 2x 6°x24° oval)
- 2 x PC cpu heat sinks (Aluminium is really expensive here, so this was the only cost effective option, but I found a few US heatsink companies on Google)
- 1 x constant current power supply (I'll describe this in detail later)
- switch
- relay
- thermal paste
- 3mmX9mm self-tapping screws
- wiring
The LEDs:
The Heatsinks:
Next steps:
- Solder the LEDs into circuits of 3 LEDs in series.
- Test using a 220v power supply connected to the mains (I bought one specifically for this. Puts out 36v @ 3A.)
- TEST I'll post some videos/pictures
- Build and test the 12v power regulator
- Test again using the Jeep's power
- Build the enclosures
- Assemble!
