Diagnostic tool and p1652 p1511
Komarengi
Hi all!!! I recently checked the errors on my 2002 CRD 2.5 with the ignition key. I got p1652 and p1511. There is mixed information on decoding these codes. After removing the terminal, they reappear and the check engine does not light up. What is this and how can I check to find out the problem?
I bought several obd adapters on amazon and tried several programs for my phone, but none worked with my car. Is there a budget option for obd diagnostics for early model 2.5 CRD's?
I've got a Launch box from ebay, works on my 03.
I think your faults will all relate to a bad battery or a bad connection somewhere around the battery or alternator.
Did you have problems before the new battery? Check your connections, the wiring and earth points
