Crunchy sound when accelerating from a stop
mtbspm
Wichita, Ks
Just today my Jeep started to make a weird crunchy popping sound under light acceleration. It only happens from a stop and only lasts for a couple seconds. I haven’t had a chance to look under it yet. It still seems to drive fine, but I’m hoping to get a couple ideas so I know what to look for when I crawl under it in the morning.
kejobe
NE Ohio
My first thought is to check the U joints. Any clunking when going from forward to reverse gears?
duderz7
Weiser, ID
My first thought was capt 'n' crunch spilled in the back seat... This happened to me once after my kid was back there
mtbspm
Wichita, Ks
No I joints would make sense. I’m thinking possibly CV joints as well. Nothing notable shifting from reverse to forward or anything like that. It also didn’t do it in my way home tonight.
JasonJ
Michigan
CV joints tend to click when they fail.. and usually on turning as the joint it is articulated.. not always, but generally.
U joints would be a good one to check, upper control arm bushings and balljoint is my next best guess. Sometimes it crunches instead of clunks.
Can you tell if it's more from the front or back? Lower control arm bushings is another one to look into.
mtbspm
Wichita, Ks
Definitely sounds like the front. It decided to get cold again, so it'll be a couple days before I look under it. The lower control arms are original, would Jeep still cover them under that recall?
JasonJ
Michigan
Only if the recall campaign is open on your VIN.
Punch your VIN into the lookup page on Jeep's website and check it out.. if it's still open and applicable to your vehicle, it'll be listed.
mtbspm
Wichita, Ks
I'll have o check that out when I get home tonight. Otherwise I'll probably spend a bit of the weekend messing with stuff under the Jeep.
mtbspm
Wichita, Ks
I just got around to checking everything out. I honestly can't find anything. I'm noticing a bit of a lip on the end of my brake rotors, and I've been getting a bit of a squeal. I'll probably start by doing pads and rotors to see what happens. Also, my lower ball joints have broken boots, but when looking at the recalls, that job was already complied with. Is there any chance they'll redo it? Concerning those ball joints, I know that I do need to replace them, but there is no play in those joints, so I'm not thinking that's the cause of the noise.
mtbspm
Wichita, Ks
Noise has gotten worse and far more consistent and it a result of steering motions. I'm thinking those ball joints are likely the issue after all, replacing them tomorrow. I'm thinking that if that doesn't do it, maybe the tie rods?
